Some real sad cases in here, try getting a life instead of a 49% return on fake stock
Good luck getting 49% return in real life :P
It's like my life is so damn amazing already. I need to play GTA to give me a break lol
Edited by ZRBE
xbl is like 70-80 a year i think?
meanwhile on ps+ ;) same price gets me free games every month.
40 bucks on eBay for a 12 month XBL sub code.
And we still get free games on XBL gold, 2 a month. ;)
Think I f**ked the stocks for the first assasination mission. Bought the right ones before the mission and completed it. Then left them in there, and now they have gone right back down :(
There is no instruction on how long to leave them in there lol. I thought they would go up more
quick save and sleep (without saving). check stocks. quick save and sleep. check stocks. quick save and sleep. ???. Profit?
I've given up, they just keep falling lol. Think I left it way to long.
All good, I'm saving the next assasination missions till the end. Should be able to profit then :)
Finding it real weird to be playing GTA and the majority of missions dont make you any money.
BTW, the mission where you steal the prototype device or whatever it is, where you can blow the boat up and get it or go to the secret test site and steal it with the sub (this is the one I did), do you lose the money on both options? I was wondering if I should have gone the other way with it or if you dont profit out of either?
both methods are a bust.
I think in all heists, if you pick the same crew for both methods, the result/payout is the same regardless of which of the two ways you go about it.
Except for the final heist. One of the methods results in significantly more cash moneys
Edited by alex182
hmm, i always pay the most out for the crew and stick with them the whole way through - get packie mcreary from a random event right near franklin's aunt's house, and pick up a driver along the north of the island (can't remember name) - use them, as the driver has good specs and only asks for 5%.
is it the drill method that gets most at the end? i went in the sneaky way, may have to try it another way this time around.
doing the 5 miles through the desert at the moment for the epsilon stuff - headlamp holding movement left and weight on X so he'll run in circles while i browse the internets :) that'll rack it up.
Btw I got a trick to buy properties for free
Purchase the property and straight after confirming that you wish to purchase then pause the game and go to the game menu.
Select to re-play one of the previous quick missions such as saving your son on the yaht.
Once you finish the mission it will take you back to your game with the property purchased and all the money still in your bank
  • Like 1
i have done a random , blue dot on the map mission, where you help 2 dudes rob a shop and help them get away, they then become people you can use on heists anyone else used them? are they any good?
keen t use them, hoping they are a god alternative to the usuals
Edited by GH05T
Yeah, you get Packie (from GTA IV) - good stats and 12% take I think. I use him for everything after that.
Also get the woman from the middle of the highway up north - good driver and only 5% take. she's at the yellow dot in the map below:
might have to go past there a few times - i've found her with Michael and Franklin, but both at night.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
