Some real sad cases in here, try getting a life instead of a 49% return on fake stock
Good luck getting 49% return in real life :P
It's like my life is so damn amazing already. I need to play GTA to give me a break lol
Edited by ZRBE
xbl is like 70-80 a year i think?
meanwhile on ps+ ;) same price gets me free games every month.
40 bucks on eBay for a 12 month XBL sub code.
And we still get free games on XBL gold, 2 a month. ;)
Think I f**ked the stocks for the first assasination mission. Bought the right ones before the mission and completed it. Then left them in there, and now they have gone right back down :(
There is no instruction on how long to leave them in there lol. I thought they would go up more
quick save and sleep (without saving). check stocks. quick save and sleep. check stocks. quick save and sleep. ???. Profit?
I've given up, they just keep falling lol. Think I left it way to long.
All good, I'm saving the next assasination missions till the end. Should be able to profit then :)
Finding it real weird to be playing GTA and the majority of missions dont make you any money.
BTW, the mission where you steal the prototype device or whatever it is, where you can blow the boat up and get it or go to the secret test site and steal it with the sub (this is the one I did), do you lose the money on both options? I was wondering if I should have gone the other way with it or if you dont profit out of either?
both methods are a bust.
I think in all heists, if you pick the same crew for both methods, the result/payout is the same regardless of which of the two ways you go about it.
Except for the final heist. One of the methods results in significantly more cash moneys
Edited by alex182
hmm, i always pay the most out for the crew and stick with them the whole way through - get packie mcreary from a random event right near franklin's aunt's house, and pick up a driver along the north of the island (can't remember name) - use them, as the driver has good specs and only asks for 5%.
is it the drill method that gets most at the end? i went in the sneaky way, may have to try it another way this time around.
doing the 5 miles through the desert at the moment for the epsilon stuff - headlamp holding movement left and weight on X so he'll run in circles while i browse the internets :) that'll rack it up.
Btw I got a trick to buy properties for free
Purchase the property and straight after confirming that you wish to purchase then pause the game and go to the game menu.
Select to re-play one of the previous quick missions such as saving your son on the yaht.
Once you finish the mission it will take you back to your game with the property purchased and all the money still in your bank
  • Like 1
i have done a random , blue dot on the map mission, where you help 2 dudes rob a shop and help them get away, they then become people you can use on heists anyone else used them? are they any good?
keen t use them, hoping they are a god alternative to the usuals
Edited by GH05T
Yeah, you get Packie (from GTA IV) - good stats and 12% take I think. I use him for everything after that.
Also get the woman from the middle of the highway up north - good driver and only 5% take. she's at the yellow dot in the map below:
might have to go past there a few times - i've found her with Michael and Franklin, but both at night.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
