Ok here is the problems, turbo is a hypergear atr43 ss-1
Boost spike to 22psi then falls straight off to 14psi
80% of the time it only gets to 16/17psi
Has 500rpm lag over most other identical turbos
Only made 306hp.
Attempted fixes.
Removed air box
Tried pod filter
Tried different intercooler
Removed exhaust
Tried different exhaust
Pressure tested the whole system
Removed boost control
https://www.sau.com.au/forums/topic/381350-thread-for-my-car-problems/
  • Replies 886
To add insult to injury. I got out accelerated by an xr6 :'(
My setup is as follows. K&N panel filter-z32-3"metal intake-turbo-jjr bellouth dump-gutted cat-hks hi power cat back-jjr return flow intercooler-turbosmart type 3 plum back-Nissan 350z 450cc injectors-walbro gss341-nistune
Notes on setup are a little disjointed.
Gearbox - auto or manual?
Boost control - straight feed to actuator now? Previously? And what difference observed?
Actuator - what pressure is it rated at? Is it set up ok? What pressure does the valve crack off its seat?
Boost delivery - do you have a dyno sheet with boost overlay? Saying it's 500rpm more laggy than other similar setups doesn't give a great insight into things, graph tells a whole lot more.
Dyno sheet - please upload one
looks like a very weak actuator, you say its rated at 18psi yet your boost is dropping off to 14psi? didnt think you can run lower boost than your actuator is rated at..
The actuator should be plumbed in off the turbo outlet, so it will hold x amount of psi at the turbo outlet. Theoretically that number should be the same as the pressure in your manifold, but only if everything else is working properly; boost leaks, pressure drop, restrictions, etc. will affect it.
He didn't tell me what afr he tuned to (annoyed me when I was driving home and realized) and I do have a torque graph, il put it up in a minute. He said he couldn't get it to hold full boost, he tightened the actuator adjustment and turned the boost control up. The actuator is plumbed into the fitting that used to go to the air con compressor solenoid?switch?
Only boost leak is through my open air tappet cover breather, holds 30psi if I put my finger in it.
i should also point out, my car makes 22 psi but doesnt feel like it makes power until it drops below 18/19, like kind of has that vvti+l feel after that.
Edited by lilcrash
if you put your finger in the cam cover breather it boosts to 30psi????
sounds like you have a strange boost leak...
maybe you should have the breathers plumbed up right and find your boost leak...? just a thought.whistling.gif
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
