  • Replies 886
yeah it does some crazy stuff and should probably be left alone
i've head ppl also say that you should take a boost source after the cooler and even from the manifold, i guess to counter the boost drop across the piping and cooler core
I wouldn't. What happens when you do for some reason get a massive pressure drop across the system? Most people (with a Hypergear turbo at least) will use an actuator that is rated close to their turbo's maximum efficiency. But if your turbo is efficient to 20psi and you have an actuator that is rated to 20psi hooked up to the manifold, and you get a 5psi pressure drop, then all of a sudden your turbo will be trying to push 25psi, which could lead to super-heating of the intake charge or outright turbo failure.
I would have the nipple as close to the turbo outlet as possible. Then at least if you get a pressure drop, you're just going to lose a bit of power and you will notice and get it sorted out.
There are lots of fors and againsts.
Some people claim it using manifold causes boost spikes as you run a longer actuator line as well as a longer pressure source etc etc.
I used to run my old TD07S off the manifold, never had boost spike issues, and I actually had a reason... I had no BOV, there fore I wanted my pressure source to my wastegate in vacuum during gear shifts rather then seeing the huge pressure in the cooler pipes. This forced the wastegate shut whilst shifting, and made the car come back on boost hard again...
But on a nice little street setup, I'd have the pressure source as close to the turbo as possible.
Ok now I can smell oil through my air con, anyone ever had this, I can't find a leak but yeah kinda weird.
OK, pretty simple mate.
Your AC picks up fresh air from the skuttle panel (where the wipers are), anything that comes out of your bonnet would get sucked into there while your driving.
If your PVC is rooted and letting boost into the sump then you are probably pushing fumes or oil out of the dip stick. Furthermore if you have done a half job of your oil breather system (noting you dont have it running to your intake pipe anymore) it would also be doing the same thing. Otherwise if you have a little airfilter on the end of your rocker breathers it could be that too.
Yeah I thought that, it only really happens when I brake. One day was a really bad fuel smell the next it was oil, that's what had me poking around and I can't find anything. Guessing it's just another quirk.
Reading through all this and the other crap that youve posted all points to one thing
You shouldnt be around cars cause by the information or lack of you do give us you dont even
know wat the f**k your talkin about.
"DAMN I GOT NEW TYRES AND NOW MY GARAGE SMELLS LIKE NEW TYRES"
I mean your persistant ill give you that but seriously do you even know wat the f**k your on
about?
By the sound of it all just sell the car and buy a push bike...
We can then see threads of "How do I lube my chain" or "Im stuck in 15th gear HALP ME"
yep sorry but this is getting funny now....
Why are you not just taking your car to a decent mechanic/tuner, really these issues your having don't sound that hard to fix really....
He will prolly blame the tuner for not having a clean smelling car soon cause of this oil/fuel
vapour thats leaking out...
"YOUR TUNE IS SHIT, MY CAR IS STINKY NOW :( I DONT LIKE YOU!"
Really reminds of of all the halfwits at work that find the old point and blame game alot easier
then just saying "Yes I f**ked it by doin blah blah blah"
Just sell the f**kin thing and rid yourself from this site...You remind me of a smarter version
of La Bomba.
Chocco you never cease to amaze me with your completely useless posts. For some reason you feel that people aren't allowed to learn about the causes and fixes for their mechanical problems.
For those interested it appears some of the oil drains in the head were blocked.
Come on leave the poor guy alone, he is trying to learn.
lilcrash all I can suggest is if someone offers some advise that sounds reasonable then follow it and give some feedback/results <- Which you have actually been doing, apart form the odd delay.
Keep cracking on you will sort it out sooner or later.
alot of the delays in testing is because i get stuck into working on my wifes car and forget about my own problems. her car is still running perfectly without an afm and it runs like shit when i plug it in. im very confused how thats possible but yer.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
