Lol. Someone came back :D.
How far is your workshop from rydges at north Sydney? We have a credit for $300 to stay there from last year when we were supposed to come down but my wife got pregnant and we didn't feel comfortable flying. I'm considering driving down so you can do my tuning.
  • Replies 886
Oh dear. If you can't tell the difference between foot pounds and nm you're screwed. Id get someone else to assemble...
Also, there is a special tool that you use to file rings.
How the hell did you do it?
I thought you were actually starting to do well... until.
I wouldnt be sure of myself with a fresh built engine, Id get someone experienced to this stuff just so I know its done right, the money spent on engaging someones experience now will be money and worry saved in the long run...
How were you going to drive down to sydney area to get the car tuned, would that mean you would be driving it all that way untuned?
doesnt sound like a good idea to me...
I read the wrong side of the torque wrench. It was only the oil filter mount and thermostat housing anyway.
I'm getting it put on a dyno before I drive it to make sure the tune is safe for running it in. And I was going to hold the wastegate open for run in anyway.
Wat?
You need pressure in the cylinder to bed the rings.
I was thinking the same thing Wolverine, I admit I have made mistakes in the past but the less people that know them the better. lol.
When asking for help its good for you all to know what has happened up until now. I've got nothing to hide. I admit I made some mistakes but it's all a learning curve.
The only concern I have is that I may have a few dog hairs in my engine, I think everything else has worked out ok.
Trust me I will be doing minimal driving until its tuned properly. With a baby on the way I can't afford to do this again.
How long does it take to run in an engine on a dyno vs in the road. Liked if I get my tune checked, I might just go for a late night mountain drive. I'm thinking mt nebo and mt mee and mt cootha all in one night. That should get me my 200km before the first oil change.
Yeah I'm using the hypergear atr43 ss-1. Going to run 14psi or as low as possible if I can't get the low.
Ok kewl, il plug it and if there is an error il know why, this big earth terminal plate is driving me nuts too.
Edited by lilcrash
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
