Hey guys,
I just put on order a whole bunch of goodies for my 34:
Garrett GTX3076R
Z32 AFM
Bosch 040 Fuel pump
Return Flow FMIC
Soon to come
Nistune board
Insert suggested injectors here (Sard 600?)
Im going to do the install myself with the help of a mate and Im trying to find if anyone has done a 3076 low mount with the return flow intercooler, Just looking for some pics so I can get an idea of what I'll need to do as far as the piping goes. The car is a daily so Its probably going to be a bit of a mission to get it done but Im sure it'll be worth it.
Cheers
S
https://www.sau.com.au/forums/topic/381709-gtx3076r-on-r34gtt/
What size rear housing is the turbo? Internal or external gate? If your using the stock manifold, you'll need a 10mm steel spacer, to space the turbo of the manifold as it will foul.
Whats the car to be used for? Street driving?
Your power goal and the fuel it runs on will determine your injector sizes as a rough guide. At the power your making, you dont want to push the injector duty cycle past 80%.
Awesome info kitto it's a .82 housing internally gated I had heard about the spacer but wasn't sure. The dealer I bought it from is looking into that for me. I'm aiming at 320 kw in the future but not right away. main use is street driving occasionally spirited and I want to start doing some track days for a bit of fun
Ah ok, from what i have personally seen and been in. The .82 rear housing tends to be a bit laggy on an RB25. Especially if your not using an EBC.
However, the first RB25 was using a GT3076 not a GTX. This doesn't make a lot of difference at all, but just a slight amount. This engine was a non NEO engine aswell using BP98 making .347 Hub kW.
The second RB25 is a NEO engine, on E85, .63 rear housed GTX3076R making 368kW on the same hub dyno. Its Simon Michelmore's S14. He's had awesome results with the GTX3076R with a .63 rear housing
Both engines were also using steam pipe high mount manifolds which do make a difference.
Running lower boost pressure may cause the boost pressure to spike as the internal waste gate can't get rid of the large amounts of exhaust gas at lower boost levels.
It will do 320kW easily. What fuel are you going to use? E85 or BP98? This will choose your injector size.
NIStune - I like it!
i wouldnt count on making 320rwkw with an internal gate turbo on the stock manifold on 98. sure it happens, but most people fall well short. realistically you'll be limited to around 260-300rwkw depending on various factors. the standard manifold also makes the gtx3076 overkill compressor wise, better off with a standard gt3076.
as for injectors if you can find a set of nismos for sale at a decent price go for them. otherwise theres a few other bolt in options, plenty of info on here if you do a search.
as for bolting it onto the stock manifold, you'll need a 10mm spacer as said, along with longer studs, nuts and washers, custom dump, oil and water lines, cooler pipe mods and a custom intake pipe.
You actually need a 20mm spacer for the 3076's. The 3071's only need a 10mm spacer.
No you dont.
You need a 10mm spacer and extended studs.
I have a 3076 .82 on my RB25, with a Blttz Return flow. the turbine outlet pipe needs to be extended about 220mm.
Heres a pic of my stock pipes modded to suit. (top pipe, you can see the extension welded on.
If you trim about 40mm off the stock manifold heat shield you can get that to slot back on too.
And dont listen to anyone that says a .82 is laggy on an RB25. They dont know what they are talking about. You will love it to bits. Enjoy :)
Edited by gotRICE?
Im running the GTX3071 with .82 rear housing .60 front in second gear at 4000rpm the lil 25 really starts to boogey all the way up to 7500rpm i was worried bout the lag just like you were mate and i have no regrets bout the .82 its a great street setup its not hugely laggy but pulls like a freight train! :)
Still waiting to get some more info for you Lith but the head gasket leaked into number 5 on Friday while on the dyno. It will be another 4-5 weeks until I get it back on there. They were well into tuning by then so there could be some preliminary results to overlay with Mick_o's car when he gets back to the tuner.
Ill be running 98PULP, maybe avgas, shouldn't be too difficult for me to get. I will be getting an EBC (like the look of the AVC-R) down the track but might go with a boost tee or similar in the interim. Damn lack of funding!!
JonnoHR31, Is that a custom suction pipe or can you buy them or something similar?
Im actually not 100% sure lith but im pretty sure 21psi in 3rd gear is around 3500-3700 max and 4th gear is unknown mate my car is supposed to be hitting the rollers thursday so keep ya eyes peeled in my GTX3071 thread mate to check out my dyno sheet. Wolverine actually drove my car the other day and was of the opinion there was a little more to be had down low. So fingers crossed hes right
When do you get full boost in higher gears? I've been really interested in the difference in overall performance between a GTX3071R and a GT3076R :)
heres what i used for the piping mate :thumbsup: .'-
Suction line/air filter line
4'' - 3'' silicone reducer
3'' 90 degree elbow
3" 45 degree silicone bend
TURBO OUTLET LINE
A 2.5"-2" reduced silicone 90 degree bend
2 x 2.5" 45 degree bends
Thats pretty much all i used as well as a short piece of 1" pipe for my blow off valve plumback line and a piece of 3/4" for the rocker cover breather line :whistling:
Garrett GTX3076R
Z32 AFM
Bosch 040 Fuel pump
Return Flow FMIC
Soon to come
Nistune board
Cheers
S
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
