how the hell would those tyres cope with 1000hp, let alone 2500hp? :wacko:
Dunno about the tyres but I would have a silly grin on my face the whole time
Actually, if it was a 10 lap race around the Nurburgring, I would put my money on the R35 any day of the week. Im not saying that this thing doesnt look brilliant (the rediculous turbo's sticking out the front make me happy in my pants), but seriously, you might as well be saying that this Supra is quicker than an F1 car simply because it has more HP.
Does it look like a circuit car?????
  • Replies 62
My point EXACTLY! Horses for courses. Which is why I was saying that your first comment about waiting for R35 owners to come and say that their car is faster for some gay reason was silly. You are the one who made the comparison, not me. That Supra is probably faster in a straight line than a hell of a lot of supercars, would it beat them around a track? No chance in hell! Is it awesome? F'ing Oath!
If you do want 200hp and A/C though
Go see Nelson Racing
This is the car that Batman would trade the Batmobile for!!! Or just sell Robin's ass on a street corner and keep both......
fap?
unfortunately, apart form the turbos ,its still butt ugly Supra at the front..
But this is possibly the sexiest rear I have seen on any car ever..and seeing as its the only view most people will ever see that is all that matters
i could really see myself commissioning a car like that camaro or supra as my daily driver, given the budget. you'd probably still want a back-up vehicle, but still. Cars like these might be pretty popular for us car guys in 20 years, as it gets harder and harder to DIY maintain new cars.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
