  • Replies 205
Western side of the WRR.
When you get onto the WRR from the Geelong FWY - you'll be on the correct side of the road.
Worth noting to all - that between the Geelong FWY on-ramp and the Mobil servo are a set of 'traffic safety cameras' carefully disguised as a road-sign. They are active and regularly book criminals outrageously doing 104km/h in a 100km/h zone.
Please be aware of this and keep it under 100 for this short stretch of the WRR (the cameras are on the first 3-lane wide sign after the Geelong on-ramp). The servo is no-more than 2km from the ramp.
thanks for the heads up on the cameras an clarifying directions. I'd be more than happy to organise a meeting point in Geelong if there are any other geelong liners thinking of going? sounds like a good drive that shouldnt be missed. Hopefully theres even more cars than the GOR cruise.
have to get myself one of those UHF radios from Jaycar or something too....
Nothing wrong with just shy of 30!
And of coarse they can come. Cruise is open to all as long as they behave (shouldn't be an issue with "older" guys). I have a mate with a TX3 that is prob going to join us.
I've never witnessed them being stupid nor irresponsible, but there can always be a first time right? I'll word them up accordingly.
And I'm not laughing at you if your post was directed at me! I've just never seen your car man and know you'd prefer to drive than to be a passenger!
Andrew: anything wrong with over 30? :Paranoid:
Then they can't come......us older guys have to behave badly...overcompensating to fit in :D
Seriously it will be good, and Ash can't have my spare 'line. Troy (yellowgtr) must surely have a couple he could put together.
No not at all (only cause Im not far away from it!!) Infact later in the year I will have to organise an over 30's cruise just so I can feel young again! haha.
It should be a lot earlier this time. Im expecting to be returned no later than say 4pm. The difference is this time we are only ever 1hr from Melb city max at any point anyways so its much easier to go any time if you need to.
I wll be 30 in 4 weeks time [yikes] - count me in on the ADULTS cruise later in the year :D
Haha - you old farts. I'm not 30 until next year :P
You're gunna get a backhand from an old fart when I see ya on the cruise.
F**k I'll be 42 on Sunday so you have a lot of catching up to do. At least I still look good and I'm very immature.
Clarkey
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
