all of a sudden today the airbag light on the dash cluster started flashing.
i tried the ignition on and of 5 times thing. the first time the light just started flashing all random, second time it just went back to flashing...
is it safe to drive till i get it in to nissan to be looked at?
will all nissan dealers be able to plug in to read the codes? im on the south side (logan) best location to take it???
cheers
https://www.sau.com.au/forums/topic/381924-air-bag-light-flashing/
Two months ago, my V35 Airbag light started flashing. I did the reset procedure and it hasn't come back on since.
It seems quite common in Nissans to get false positives but if you've done the reset procedure correctly, definitely get it checked out
Edited by o2bfit
  • 8 months later...
well mine keeps coming back on. 2004 sedan . I did the procedure 3 times now. and it comes back after a while. does anybody know what might need replacing? air bag modules? doe sthe g35 part work
There is no way we can answer that question. you need to have the airbag codes read to find out what it triggering the light.
The anti-submarine units in the seats seem to be a common issue, but until you get the codes read, you won't know for sure.
From what i have heard, you can't buy these units separate from the seat.
Edited by sonicii
thats what i got told too....apparently its a two yellow cords under the seat that get stretched or pulled out (couldnt quite hear the guy as the signal was crap over the phone) but i did the on off trick and it hasnt come back....yet
  • 4 months later...
Can someone advise me on how to reset the airbag light flashing? It is not really that clear how to fix it from what I have read here. I had a new car stereo put in yesterday & now all of a sudden the airbag light is flashing.
Method A:
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
Method B:
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
Sourced from G35Driver - Thanks G35man04 and SFLG35
http://g35driver.com/forums/repairing-detailing-diy/163319-diy-airbag-reset-instructions-03-07-g35-coupe.html
  • 4 months later...
  • 1 year later...
clearing the error only treats the symptom, not the cause.
You need to find out what is triggering the error.
The unit under my passenger seat was causing problems with mine, the light would come on once every couple of months. I tried cleaning the connectors and cable tieing the wiring in place, none of this worked.
I ended up dismantling each connector and soldering the wiring into the connector pins, cleaning up the pins and re-assembling. I haven't had a problem in over 6 months now.
I would offer to help, but I have no idea where you are located James. You need to get it on a Consult 3, even the above procedure doesn't work often to reset the light, and the code is still logged in the ecu.
I think all have the unit under the seat. it isn't an airbag in the traditional sence, but more of an 'anti submarine' device which stops you sliding out underneath your seatbelt in an accident, but it is still part of the airbag system, so will throw the same warning light if there is an issue.
Anti submarine rams... I have yet to see these. How many yellow wires were under there?
All the cars I have worked on had only one pair of yellow wires, and these just go to the switch under the seat to tell the airbag module there is a person sitting in the seat.
They are on mine, and I probably made a bad assumption that they all have them.
I have completly stripped my drivers seat to repair the broken lifter bracket and there is no switches, just a long tube across the front of the seat with airbag/explosive warnings on it, and a single yellow harness, but from memory, it had more than 2 wires.
The passenger side has the same thing. Although I haven't stripped the passenger side seat to the same extent as the drivers side, the module and harness looks the same.
Edited by sonicii
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
