hey guys.. weather is warming up again and i still have cooling system woes and nothing i do seems to solve it. Ive tried various things and nothing seems to work :S
currently has
RB30E fan hub
RB25 neo fan blade
shroud
brand new GTR calsonic rad
new water pump
new thermostat
good coolant
problem was huge at an event just gone.. was 30+ degrees and with just one lap (drifting, lap last 30 sec's tops) temps go from 85 degrees to 110 and oil temp around 100-110c. if i run the water squirters i have for the cooler/rad it comes back down to 100 but no lower. then if i do a few more runs it just gets real warm and coolant sits at 110 and oil at 110-120 :S
cooling sys is bled and head was off not long ago and checked for issues.. none found and MLS gasket and ARP studs fitted and reinstalled. havent had an issue lately due to mild weather but yeah even then with extended runs the temps will climb.
thinking about chucking two thermo's in front of my intercooler to force air thro them and the radator. only thing i can think of is that because tghey are close together then the clutch fan is finding it harder to draw air thro.... but im open to suggestions.
https://www.sau.com.au/forums/topic/382240-help-me-solve-my-overheating-woes/
  • Replies 52
do you run a bar and plate or tube and fin intercooler and how thick is it?
do you have any shrouding and/or ducting to force air through the radiator with no choice for it to escape elsewhere
are you running a shroud around the engine fan?
Edited by blue_vl_t
yes as far as i can tell it is working correctly
ive got a tube and fin I/C its located 10mm in front of my radiator. its 76mm thick also.
i made an alloy under tray and an alloy air box to funnel air from front bar to the intercooler. this helped at higher speeds but doesnt make any difference at low/medium speeds.
Edited by Simon-S14
Still having issues Simon?
I thought you fixed all your issues after put in a brand new factory radiator?
A large radiator isn't necessarily going to fix the issue. If the coolant passes through the large radiator too fast, the radiator doesn't have enough time to dissipate the heat from the coolant.
Is the GTR radiator you have a single or twin row one Simon?
Failing fan clutch would certainly be a look in!
Considered a Nismo low temp thermostat? Not ideal,but your radiator is never going to get heaps of flow over it because of the low speeds and angle your at :P But your still asking huge amounts of work from the engine, so it will want to get hot.
Are other guys like Hayden having any issues?
nah haydens car never overheats. so defo something up with mine.
due to it being a silvia engine bay im restricted as it is. i can only just fit the clutch fan in with a stock GTR rad (which is twin row) anything thicker and i cant fit a shroud. I used to run a ASI 40mm alloy rad. but had issues with that also!
i will chuck another clutch fan/hub combo on and see how it goes
sofitting termo to the front of the IC not gonna help much?
When I went to a front facing plenum I re-routed all the coolant lines to bypass the stock oil to water cooler and I used Castrol radiator inhibitor fluid(just a simple anti rust solution).
Now my water temp sits around 70-74 this is with the stock rad/water pump/fan/thermostat, before i did this it would sit around 80-84. Also now it takes like 10 minutes to warm up so not ideal for a street car.
My turbo is oil cooled only so this could be a big factor also.
Ever tried Redline water wetter Simon? had a few mates use it when they had slight overheating issues and it seems to help. Or maybe get a 52mm radiator, and run twin thermos (not exactly cheap though is it).
So you reckon retaining the factory oil warmer/cooler is no good for performance application?
Well I removed it because all the pipes needed to be changed, I had a dedicated oil cooler and it just made sense to simplify the piping to reduce points of failure.
The unexpected side affect of this was that it drastically reduced running temps... I never had temperature issues before so to be honest it would be better to run it just to have the shorter warm up period.
It seems like you have tried everything else so I thought it was worth a mention
I wouldn't call the ASI radiator decent though? That's the problem with the cheap ones, they are bigger etc, but the water runs through them too fast and they don't cool much so motorsport applications it's a struggle.
A good triple-pass rad from PWR or similar is around $800 if memory serves correct, not cheap but they do exactly what they should.
Could you get a better rad and make your own shroud up to suit? Or even cut one up? Wouldn't be "too" hard, just more a fiddly/time consuming job than anything else.
You should try and move your I/C at least another 15-20mm further away from your radiator. With it only 10mm gap how it is airflow can't get in from each side of the radiator, you'll just be forcing air that would usually direct into the radiator through the head light holes and off into the wheel wells.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
