  • Replies 48
i measured back pressure on a -10 equiped rb2630 we had at work that just would not makle power over 18psi.
on 14psi there was 25psi back pressure. on 18-20psi it had 35-40psi back pressure.... (30psi boost guage the needle wraped around to 0.. and our dyno can only read 30psi.
What power did that particular engine make on your dyno?
Just need someone with 2530/-5 to take the plunge and try a cropped GT30 exhaust wheel as above and use the HTA 68 front wheel and hope for the best! If its to laggie 3ltr it!!
you want me to try what? :D
i'm in Melb, dealt with Stao quite a bit before with my GT-T, nice little high-flow on that car, punchy little number.
So what are we trying to do with the 2530's? in laymans terms, i'm terrible when it comes to turbos, other than a 3071 is less laggy than a 3076, basic crap like that :D
are we trying to make them more responsive and powerful at the same time, or just more top-end out of them? I'm running 2530's in the R
Attempting to push 2530's harder! Whats the consensus of whether to open up the entry to the wastegate flap on hks 2530's? More area on the flap would apply more force to blow it open?
These could be my next upgrade (4th set) of actuators the dual ports look real nice!
http://www.full-race.com/store/turbos/borgwarner-efr/efr-dual-port-internal-wg-actuator.html
Now i wonder if running boost pressure to the bottom side of the gate will enable me to crack 30psi up top with the 19psi actuators or head straight to the 35psi units? Be interesting to see base pressure with the 35psi ones! :domokun:
The reliability of the stock extruded manifolds are great but at 460awkw i wonder if theres power there aswell?
Nice looking actuator!
Where did you get the manifolds extrude honed?
Berry's GTR used to be (still is?) on stock manifolds, surely they'd know if it's a restriction so maybe call CNJ Motors in Queensland and see what they have to say?
UAS organised the honing back in 2004 not sure if there still doing it..
Maybe hypergear could join the conversation with a few options on high flow bolt in low mount GTR turbo's that give 50-60AWKW extra than current offerings without masses of lag??
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
