Hello everyone.
Today was a sad day for me. I found out I'm in need of some new wheel bearings (specifically the rear right ones) and a steering rack end.
the parts are priced reasonably, but im wondering if anyone has any suggestions for cheap labor thats actually good. I talked to trojan today and their labor costs are causing the repair costs to easily hit $1000 which im not exactly happy with spending at the moment.
https://www.sau.com.au/forums/topic/383729-repair-stuff/
that would help heaps if someone could. So far Kasko is looking in to it. Basically 1 grand at the moment for my car just isn't worth it, which is pretty sad to say. The wheel alignments and stuff the car will need after can be done cheap, so thats not a problem
https://www.sau.com.au/forums/topic/383729-repair-stuff/#findComment-6121462
actually the labor worked out to be more than parts. I think I'll order the parts first, then consider doing it myself/getting help.
but can someone explain the whole bearing situation; when someone says the bearings need to be pressed in, is that the bearings or the assembly? cause I read a thing on here before and im pretty sure the guy just jammed that stuff on
https://www.sau.com.au/forums/topic/383729-repair-stuff/#findComment-6122357
well me and my dad we changed the front right one on my brothers R34gtt and it was not to hard. basically dad did all the work, i was just passing him the tools lol. Hes Fixing my R33 and also the R34 at the moment but if we were not busy we could have helped you out. ill ask him about the rear ones and let you know whats the story with them.
Cheers
Shiv
https://www.sau.com.au/forums/topic/383729-repair-stuff/#findComment-6123039
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
