Had one of leons cruse control installed before the long week end and wow was it great to use, drove to the hunter valley.
i had it stalled by a pro took him a 1hr and a half money well spent if your in sydney i can recomend him if you don;t have the time to do it your self.
rudi :whistling:
Bout time leon you pimp you knowledge out on sau.
Too right Leon; no one expects you to be a charity, well & truly entitled to something for all your hard work, and after sales assistance.
To anyone thinking of doing this; it is a purchase that pays you back every time you drive. It is a beautifully integrated system, and Leons backup is second to none.
Leon spent loads of time walking me through the install & setup of my kit, and made the whole job so much simpler, I can't recommend him highly enough.
  • 1 month later...
Lost my contact due to a computer crash a while ago, but I'm getting somewhere finally. Should have more news after my new buyer emails back to confirm prices.
Thanks for your patience.
  • Like 1
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 5 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
