  • Replies 5.5k
Posted Images
Who would have though a Venezuelen pay driver would have brought Williams in from the wilderness. Senna is going to have to lift his game. As are Red Bull.
Just hope that fire is not going to cost Frank too much money. Anyway, looks like winning stuff is good for the share price:
http://quotes.wsj.co...teractive-chart
Edited by djr81
5 place grid penalty for the Schu next round to confirm whose fault we all knew it was regarding the Senna incident
I don't know about the Schumacher penalty... Watching it at the time, I thought it was all Michael's fault, but this slo-mo shows Senna drifting right initially (there's a clear refence with the pit exit line). That led Schumacher to commit to the outside, then Senna jinks back to the left to cover that move. That's a second move to defend position in my books. But even if you don't agree on that, tell me the subsequent move to the right by Schumacher wasn't caused by Senna's sudden jink. Its all pretty clumsy, but I think a 5 spot penalty for Schumacher causing that crash is a bit harsh, when it was just a reaction to Senna moving back to the left on him and probably worried he was going to run him off the road. If Senna had kept going left, they probably still would have crashed because it was all too late...I just don't think you can put all the blame on Michael there - he wouldn't have made that move back to the right if it wasn't for Senna's sudden jink back towards him.
http://www.youtube.com/watch?v=kfls8VLYZr0&feature=related
Senna only moved once to cover the move the again back to the racing line which apparently they outlawed that at the beginning of the year but every has been doing it all year so you can't blame him for the crash if they have any consistency.
Clumsy on Senna's part, but at MSC should have left himself more room so he takes at least 75% of the blame in my eyes.
MSC was whining about Senna braking and moving back to the racing line like it was a sin but there is no rule against that is there?
Edited by NISMATT
the sudden-ness of that Senna jink was not a "I'm just returning to the racing line now, ok?" That was a "get stuffed, you're not going that way" sort of move. He didn't go through with it, but turned out Schumacher bought the "dummy"
Yeh Schuey had a "I am confused moment" and ran into the back of Senna...easy to see how it happened with Senna moving around like he was...racing incident to me and doesn't deserve a penalty
Re the pay driver tag that Pastor has had to wear...as a rookied he did a knock up job alongside Rubens, he was impressive in Australia despite dropping it on the last lap...and he drove a damn solid race, strategy was good, out lap pace was waaaay better then Alonso and was still able to get the required life out of his tyres. So stoked that he got the job done....hopefully the tag of pay driver will be forgotten as he obviously has the ability....$10 the likes of Fisi and many others would have made mistakes .... seems like 2011's pay drivers Perez and Pastor actually have the goods
well that all depends on whether he can finish on the podium again this season...
Weber ploughed right up Kovalainen's arse in Valencia 2010 under similar circumstances with DRS open and a high closing speed, and a car in front braking early due to worn tyres. But no dummy jinks from the car in front, and Weber didn't even pull out to try and pass one way or the other. Just ran clean up his arse without even braking. Did he get a 5 grid spot penalty??? no... nothing at all...
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
