  • Replies 5.5k
Posted Images
the one pass i remember was the one i gave at around lap 50 when i turned it off and watched UFC 146
I got your back for next year- I've directed race control to allow faster cars racing slower ones for position to overtake on the escape line through the pool complex without penalty
sorted
STOKED :w00t:
http://www.nieuwsblad.be/article/detail.aspx?articleid=PO3QF1PK
Seems as though French GP negotiations are not progressing to plan under their new Socialist govt. Hopefully this means Spa aren't being strong armed with " I will take the GP elsewhere" talk. Come on Bernie...do the right thing!
that chicane should be gone altogether
what a run out of the tunnel that would be!
I agree, but I can totally understand the FIA's position of not wanting the cars to be arriving at the braking zone for Tabac at ~330km/h...
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
