  • Replies 5.5k
Posted Images
What a CARNT weekend from a CARNT sport. I give up. For the second week in a row Dan got mugged on the last lap or so. What the hell happened? 10th to 12th on the last lap..Senna do a desperado and Maldanado sneaked through as well?
Daniel Ricciardo (12th)
“It’s been so hard to score points this year and that means it is incredibly disappointing not to get one today. I was tenth until the last corner on the very last lap. At that point, I accelerated to exit Parabolica and nothing happened. At the moment, I don’t know the cause, but to miss out on a point by a few hundred metres is bitterly disappointing.”
I wanna see good points from both drivers from the balance of the season
i want to see button concede his title aspirations for the good of the team, and face reality for once in his life
chances are neither of us will see these things until its, once again, far too late
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
