  • 6 months later...
here are some pics of a local newcastle engine builder & his latest project.
gtx snails with a few other goodies...take note of the intake plenum & flux capacitor. absolutely awesome fabrication work!
Hey Marko,
did that engine or intake and cylinder head come from VIC?
some very familiar parts on there ? :)
  • 5 weeks later...
I'm just about to do a cartridge drop of a pair of GTX 2863's into my -5's next week with the modified front -5 housing, I have seen GCG have said it wouldn't work? but I'm pretty sure you can't go backwards than having plain -5's.
I am running this on an RB28 HKS engine, and was even looking at the 2867's, but I'm not very confident I need the extra power, and the response would start to suffer a bit.
My -5's have a slight oil leak developing and this is the reason for the change, but I was worried about the 2" -5 housing as opposed to the 3" one on the complete turbo, do you any of you really see the benefit of changing the whole turbo over when the -5 mods looks very viable, especially with a drop in type approach by comparison?
It looks like status saw some good results from this approach, has anyone else done the -5 rebuild with GTX cartridges?
I seriously this needs to be looked at, because it would be great for people with -5's to upgrade far easier and cheaper than the other way.
Sean's job looks great though, and would be the other way I would do it with a complete GTX item, bar the exhaust housing.
  • 4 weeks later...
Just got my car back with the GTX2863's in my -5 housings, and it is heaps better, I have 30psi with 638hp at the wheels on E85 now, and the response and power in the mid range picked up heaps.
  • Like 1
Cams are now 272/ 9.7's I would probably go back to 260's for a perfect combo, but even the big overlap with this GTX upgrade it feels pretty darn near perfect for response and power. I went to the track yesterday, and the corner exits were pretty much bang on, even with 2nd gear short shifted into 3rd it still had plenty of mid range to keep it pulling really well.
The green graph was the power level I had last time, and now this is the new figures. I unfortunately had coil pack failures on the 3rd lap into my day, and the power level had to be dialed back down. I was trying to break the lap record for fastest street car record in QLD and I only had 2/10's of a second to have it. With the extra 80hp I was sure to have it, and the laps where everything was fine, I was driving pretty carefully whilst monitoring temps etc from my recent head gasket change and turbo upgrades. I am now selling my car and don't know if I will have a chance to try again. The potential for this thing now is truly getting crazy, it has been an amazing car.
1375911_10151736479018907_1474853925_n.j
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
