Lol at this fool! You know absolutely nothing about me or what im capable of or who I work for. You've produced absolutely no evidence as there is no evidence its all hear say! Thats why you've done nothing but speculate results in this entire thread and why you are waiting to see other people spend their hard earnt on the turbos and see their results ya muppet! If ya so sure of yourself why not just get your turbos? When i asked you your claim to fame i got a fapstick reply? So whats your experience with cars & why should somebody believe Mr Skidmarkz over Mick_O?
Pretty sure theres quite a few guys who could vouch for my experience and knowledge in here. How many can vouch for you?
As for the graph you posted as proof that i didn't know SHIT. The owner of that car wished he just went a single a little birdy told me :)
I've never heard so much shit come from one human ever.
Your a f**king joke.
You clearly have an over inflated view of yourself.
I've countered all your shit talk comments with accuracy and all you got to say you simple f**k is ....aaahhhh...... yea your a f**k wit mate.
Please
High PSI and big tight bends in pipe work create heat, the tight pipe work will create a lot of heat.
EGT temps are crucial when you get up to this level, along with intake air temps, this all worked out alongside PSI all helps with heat and efficiency big-time :rolleyes:
  • Like 2
Great posts Simon! :)
You pretty much confirm what ive been trying to say about the limitations of the stock position/bolt on GTR turbos when you start looking for 450kw or more on twins the choking turbines cant cope :)
  • Like 1
Yeah choking it is definitely a term I would describe it as, I know Paul says this. I have always been against singles............until I hit 600hp ;) I would have loved to have kept it and done the development on it, it get's very interesting and challenging.
Lol you're a f**kwit mate simple! This isn't wasting space on the thread at all! People need more than just your opinion on here. Clearly yours is uneducated & now you've got nothing to argue you wanna get all "PM" on me!
Be sure to post your results and prove me wrong soon as you stop sitting on the fence and dreaming up what these "hybrid turbos" will do with all your theories!
Agreed!
Mr Skid = Fu#kwit
Most people dont' change their 3" cooler piping out anyway Of course to flow 700hp of air out of some of the singles you don't need 30PSI which probably helps just a tiny tad....
Will be interested in seeing how the 60's go as they won't be putting out as much power.
  • Like 1
Wonder if the piping factor contributes to the massive gains in zed world? I have full (2x, 1 for each turbo/bank) 2.5in piping and cooler in/out etc. The graph i posted the other day has custom 3in piping (x2). The perth zed also has custom piping which i think is 2.5in.
Micko is saying the "chocking turbines can't cope" and is restrictive, if that's the case it doesn't bother the z32 setup.
The heat Simons setup saw would definitely be contributed to the factory inlets on a RB.
Biggest exhaust in the world won't help with a smaller intake,
That's the reason race cars and bikes run there race class restrictor on the intake side.
Simon told me he also had a 3.5 exhaust which chokes the system at HIS power level generating unnecessary heat.
My Z32 had twin 3" straight through with big intakes.
Edited by mr skidz
Didn't bigmikespec say the same thing as Mick_o did about the turbine wheels, either at the start of this thread or piggaz build thread and get shut down?
It seems good, but you dont get exhaust housings when you buy a brand new one just like the rest of the GTX series. But you can re-use the standard housings from the GT range.
Plus, I still dont see how these turbochargers will be overall "better", when it is essentially a new compressor wheel that flows more with the same turbine housing and wheel. The problem with these turbochargers is the restrictive exhaust side when trying to squeeze the most out of them.
Yep.
If you wanted to run a max of 600whp on a RB28 which is a shit load for a street car, especially with 4 10" tyres AND STANDARD LOOKING ENGINE BAY!
If I were to use a GTX63 and put 27psi not 33psi like Simon did only the 27 through factory RB inlet pipes it would move more air than -5's at every point of the Rev range given the 3.5 millimetre larger compressor wheel (until such time the turbine wheel does get overwhelmed with gas it can't discharge quick enough)
which in this case won't be until 560+kw which I won't see nor do I wanna see.
Longevity and OEM looking engine bay and keeping rpms lower is my preferred engine setup.
It's not a race car it's a street car
*Hence the E85
*Higher comp
*Longer stroke
*Shorter duration exhaust cam
And sum other little tricks...
Doesn't seem a real advantage for the effort when -5s get pretty close to 600hp on e85 without all the possible negatives that people have mentioned. And the other point being that gtx tech really only outperform the GTs at higher boost levels so then again what's the point.
  • Like 2
*Making same power on less boost = advantage
* the negatives mentioned are are basically the inlet piping which people use at 33psi and i wouldn't have be nothing to do with the turbocharger itself we can't blame the turbo for factory RB inlets tho.
It does pretty good I think considering.
Edited by mr skidz
I have run RSs to 28psi on a 3.0 with factory pipe work ( except ARC cooler, Z32 AFMs and modded TT pipe ) with no issue, holds boost @28psi perfectly to shut off, but power starts to fall over from around 7k through to the 8500 redline, which I have put down to the exhaust wheel/housing
but the 3.0 moves alot more gases @8k then a 2.8 which obviously moves more then a 2.6
Which brings me to my next point, what is the restriction, the T28 wheel or the 0.64 housing ?
If it is indeed the wheel then the larger housing won't do a great deal of anything to help power or response
  • Like 1
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
