Im releasing a new product next week as well.
The first ones have now been fabricated and fitted with excellent feedback.
Offereing a new sealed & vented light weight alloy battery box.
They have a hinged, securable lid with a substanciable base plate to bolt down to the vehicle. Cable glads to seal around the battery cable and prevent chaffing. Built in battery retaining clamps.
Perfect for guys looking for something thats more appealing than the old school plastic battery box that still vents into the cabin and looks rather ugly in the boot next to their fuel system or dry sump setup.
Pics of this asap been looking for somthing like this...
They are fabricated to suit any size battery you nominate
The majority of my customers are now using lithium batteries which are incredibly small and as you say battery boxes haven't changed for the last 100years they are still huge eye sores in the boot or back seat
On average a basic half starts at $660 and can go up to $1300.
A full cage starts at $2400 and can go a high as you like.
Most full cages people opt for a few extra bars over a basic cage and they end up spending around $3000.
The majority of half cages end up around the $990 mark once you add things like harness bar, double diagonals etc.
im looking into the main hoop with the 2 bars back to the rear struts, a bar going straight across in between the rear struts and a diagonal from drivers side back across to passenger rear strut.
what would that cost?
$880 for the cage in 4130 and an additional $3800 for the FEA simulation and FIA homologation which you won't obtain being a half cage.
The only way to do a 4130 cage which doesn't require FEA and FIA homologation is to have a cams recognized builder (of which I am) submit an additional dossier outling the reason for 4130, detailed CAD drawings and bar locations. ( dossier is not accessible by just anyone from cams)
CAMS will only issue a certification number if the tube
specified still meets shedule J requirements.
4130 is the same weight as CDS. The only reason 4130 cages are considered lighter is due to the reduced wall thickness required to obtain the same strength.
A "CAMS" approved 4130 cage will be same weight as a CDS cage only 3 times stronger.
An FIA homologated cams recognized 4130 cage will be 12-20% lighter than a CDS cage and usually the same strength in most tests.
CAMS charge me an additional $160 for the dossier each time I submit one for a material variance (4130 as opposed to shedule j materials)
I have FIA homologation papers for a fair few full cages now (I usually go halves in the homologation cost with the owner for the first cage design and I keep/own the papers afterwards)
However it's never been worth even trying to obtain FIA homologation for a half cage, I've almost ceased doing half cages myself as the demand for comprehensive full cages has been so high as of late.
Sorry to keep bugging you Brad, I know you're busy, but I'm getting quite desperate with my catch can situation as I don't want to get back out on the track until I've sorted it out. If you could reply to my PM or email as soon as you have a chance I'd be hugely appreciative. Alternatively I could take it to my local alloy fabricator, but I hate to take the chance that they ruin it.
Thanks again mate,
Martin.
Have you got it marked out ready to go Martin??
If so get it over to me this week and I'll have it done the same day it arrives.
Yeh mate, it's all been marked out, ready to go. I'll send it off express on Tuesday when the post office opens up again, so should arrive Wednesday?? What address should I send it to?
*EDIT* Scratch that, just calculated express postage to be about $100 each way. Will have to be standard postage then.
Edited by Hanaldo
The lithium batteries are pretty awesome, but for a road/efi track car you really need the expensive ones which are around $1100. The cheaper ones are perfect for carby race cars that don't have electric ignition systems, headlights, electric thermo fans etc. I cant justify that sort of money so was a little gutted to throw the basic, ie heavy dry cell battery back into my car >_<
I do agree Troy.
Ive managed to source some slightly cheaper alternatives but they still reach to the $750 mark for an Li battery. Most of the guys who are chasing serious weight lose in race cars are going for them.
Alot of guys with road goings cars that arent as full on tend to use the smaller drycell batterys which obviously work fine just heavier.
Ill give you a call tommorrow about your car and collecting it too.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
