Hey Brad,
I know it would be covered before, but I'm having trouble finding the info.
What size tube are all the cages made from? How thick are the walls?
Thanks.
Easiest way is just read cams schedule J because hoops rear legs front lets etc have different sizes.
Good idea, I thought of that, checked and didn't know about the different sizes required.
"Main roll bars and lateral rolls bars - 44.45mmx 2.5mmor 50 x 2.0mm"
"Lateral half roll bars and other parts of the safety cage - 38mmx 2.5mmor 40mmx 2.0mm"
Thanks!
Thanks!
Yeah theres alot of little rules in there I made sure to read it number of times before building my own cage to make sure no mistakes lol like they say measure twice cut once.
Brad, you must be a busy boy. 3 weeks and still no reply on the hub conversion that i asked about.
PM me your address and ill drop past your workshop as soon as i have a day off if it would suit you better.
My rims will be here in about 2 or 3 weeks and ill need to get em mounted up.
Cheers mate.
Its all good mate. I suppose its a good enough excuse lol.
I hope everything is all going well with the anticipated arrival.
When you can, let me know what you think. I have sent you a pm a while back with a few details.
Cheers.
  • 1 month later...
  • 1 month later...
Guys contact me via email please
[email protected]
Please can you confirm this is the ONLY email you have any correspondence with.
I have been having some personal problems that Iam working through & trying to keep things on track at the same time. There has been some delays which I'm apologetic for. I in now way have any intention of doing the wrong thing by anyone.
I don't want this to be an open conversation. If anyone has concerns please email me and ill discuss the concern with you.
Brad
  • 3 weeks later...
Still no contact
I just emailed my bank details for the refund as agreed.
Ill give ya 24 hours to finalise our issues
no contact and I post details of my profab experience
Any update on this fatz? Would be interested to hear your story.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
