OK boys, i know this is a long running 124 page thread and decided to start a new thread hopefully with more data and facts instead of personal opinions of whats works and what doesn't. Hopefully if we all work together we can work out what roughly is a good oil for our (babies) depending on application. We know the obvious, my car his car different, therefore we need to treat them differently.
So i have gone to the trouble of going through some of the technical data sheets of the oils i was interested in (please note this) and if you are able to get me others i will add them to the table so we can compare the specs. The main point of this thread, is to find a cost effective oil that shows the best value of money. I know some of us can afford to have the best gear, fair enough, but for the lay man, i hope this thread helps.
Please note, lets try to keep this thread under 100 pages lol. Anyone with mechanical, technical or otherwise expertise in this area please feel free to comment and explain to the rest of us how relevant the data compiled in this table is, as like the rest of us I'm using a oil in my 33gtr (Nulon) and it feels ok but at $60.00+ a change i think i can get better but i just dont know what to get. Any advice would be appreciated. I ve saved the table as a word.doc so if anyone whats it to add to it go nuts.
Oil data sheet.doc
Edited by Mr R32 GTS-T
https://www.sau.com.au/forums/topic/385118-the-goods-on-oils-cleanup/
if you read through the 124 pages you would realize that the basic rule of thumb for any RB engine is a common groupIV synthetic somewhere in the 60$ range is what you need. Brand isn't really that important and is more a matter of personal choice...
lately castrol edge and motul 8100 seem to be the favourites, but that may change as new oils are always being produced
Thats really all there is to know..
BTW mobil delvac is diesel oil..then again subarus do kinda sound like tractors maybe thats why they like it :D
Thanks man, but i after all i was reading so much about what people had experienced, i was going to go with the Mobil 0w-40 but then someone said it burns too quick, then i thought i go something else, but then someone said this, catch my drift. i thought providing some data can shrink a massive thread and get us to a medium somewhere as to which oil the population prefers to having running in their RB's and is more consistent. Hey at least i got one reply ta.
Delvac 1 5W-40 is a multi-fleet oil, and is SM/SL compliant. So, perfectly fine to run in our cars. It used to, and may still, have better HTHS than Mobil 1 0W-40.
Dont know about plain Delvac 15W-40, IIRC its not synth, and may not have Sx compliance. If that's the case, avoid it.
Oh, and I havent updated this in a while;
LINKY
FWIW I'm running Mobil 1 0W-40. No problems.
Thanks man for the heads up re Mobil 1 0w-40, i was leaning that way and at $59.50 (when u purchase the 20l drum) its a bargain that i cant surpass.
PS. I love the table, but like mine i only understand half of what that stuff means. Thats why i started the thread, hopefully someone will come along and say hey this means that and this is why this is better lol. im looking for the easy way out, but yeah reading through 124 pages does your head in.
WRX's i dont mind the sound of an EJ, definitely best four cylinder sound you can get. But an RB with a screamer pipe.........thats something else!!!!!!
LINKY
yeah i knew it was fine to use delvac but there is definatley better oils to run for the money
I see it alot at trucks supply shops as it is primarily meant to be a diesel oil I belive
Can you supply a supporting argument to that statement? Especially what "better" means. :thumbsup:
And what's the implication of that for its use in RB's?
FWIW I ran Delvac 1 5W-40 for a couple of years in my RB26, and in my previous car for a couple of years before that.
and you dont run it anymore because..?
They changed the formulation when it became "ESP" and didnt publish the HTHS. Oh, and I CBF driving to Homebush to get it now that i can get Mobil 1 0W-40 from the ebays for $65.
k so im using torco oil. 20w50 sr1. its apparently awesome stuff, on par with motul and big in the motorbikes. my engine builder swears by it and so does my tuner. torcousa.com. after changing from a run in oil to this i noticed a more stable idle and definately more power.
You can buy Mobil Oil cheap from LubesDirect based in Penrith, i buy in 20ltr drums, its better and you have to do it less often. I have just purchased 20ltr of 5w/50 (as advised by my tuner) for $267.00. Not bad I'd say for a synthetic.
Any Mobil Product called Delvac is primarily a Diesel engine oil, but it does have a petrol rating.
When looking at the API specs if the first letter is a "C" (Compression Ignition) its primarily diesel engine oil, if its a "S" (Spark ignition) its primarily a Petrol engine oil
Example
Mobil Delvac MX is a CI-4/SL
Mobil 1 is a SM/CF
The letter after the C or S represents its peformance leval for petrol or diesel
Its not a problem to use a diesel oil in a petrol engine, so long as the "S" rating is the one you are looking for. API "SN" is current.
The new API SN spec is designed to handle the problems of using E85 (85% ethanol) fuels
Link to what the API specs are API Clasification
Here are some of our United Oil synthetis products
United 171 Racing Double Ester
United 1 5w50 PAO/Ester
United Ultimax Racing 10w60 PAO/Ester + Moly
I hope this helps
Ash
Edited by kingscorp
im using the united 1 5w50 and i find it brilliant its a weekend car i have used it for about 500kms now with no problems great cold starts and great oil pressure on idle when warm etc. i had mobil1 5w30 in mine for 2000kms it was sh*t broke down after about 1000kms. they use it in HSV's which are alloy so maybe good for a N/A engine but turbocharged mst heat it up to much and it tends to break down
i Highly Rate the united oils from kingscorp. and i will from no on be buying it in bulk from him. any questions about the oil feel free to contact me
Edited by luvpsi
Im using castrol edge 20w50, Castrol is good stuff I think.
I once used Fully Synthetic castrol edge oil in my old evo 5, it started blowing smoke and using oil so it must of been getting past the piston rings being like water. so had to resort to thicker semi synthetic to fix the issue. (had around 90 ks on clock)
as for my R32, what im using is prob a bit thick because the oil press gets way up there! it has a rebuild and forged engine (a few years ago) so im thinking of trying fully synthetic in it instead.
I guess what im saying is use fully synthetic oils for newer fresher engines and semi synthetic for older used engines. and choose the weights accordingly for how you use your car
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
