Hi guys, after much deliberation, i am going to throw together a quick build thread that will evolve over time as the engine is built. In this ill try and give out as many pointers and tips as to what im doing/done and why ive done/am doing it.
OK, where to start....
I purchased the car back in 2002 from a small importer in brisvegas for a princely sum. It had a catback exhaust and that is about it. I was pleasantly surprised by the grunt it had and the klms were what sold me on this car. 38000k's on a neat 97 s2 MP1 coupe. These K's were verified by a friend i had in japan after we scoured through the service history of the car, so i was reasonably pleased
I was happy with this power for a few years and after running nearly clinical and consistent 12.5sec passes at our local goat track, it was getting to me. It started when i blew up the box after a spirited drive at a khana event. I purchased a PAR box(NEVER GAIN) of which we had removed and fixed no less than seven times. While this saga was unfolding i got a little edgy and spent a few bucks on a set of fujitsubo front pipes, hks dump pipes, k+n panel filter, vi-pec plugin, 550cc denso injectors and a set of -5''s. After it was all sorted i made a semi healthy 477whp but never got to take it to the track.
Before the trackwork could commence i purchased a set of camtech camshafts from a forum member which came up at 266deg. 9.45mm lift on both the intake and exhaust so off to a local shop it went to have them installed. It took 5 weeks for the work to be completed and cost me just shy of 1200 bucks, neither of which i was happy with. When the car was started by myself it was very very choppy at idle and excessively smoky. I thought hey, maybe its like this as it is in need of a tune due to the camshafts, so i started to putt it down the road like a 75year old in a lambo, scared shitless id break it.
I neednt worry, it broke itself....I seen the oil pressure guage drop to zero, the engine stalled abruptly and it was making a god awful knocking noise. Onto a tow truck and back to my house so i could kick the missus' car out of the garage and throw it in there. I checked the oil, good. checked the cam timing, good, then i noticed an odd nut on the turbocharger outlet pipe. I looked further into it and noticed no washer....
So, out with the engine and guess what i found in the sump.....a nice little washer. after i pulled the oil pump i found the nut. Not too impressed, many words were said, many ales were drunk, much a tear shed.
So what to do? I called up brad from spool. Asked about a rebuild kit and he happened to mention a bit of a special on his stroker kits....i was sold, the wife on the other hand, she was preeeeety pissed. After some persistend smoothing, back rubs and general ass licking i purchased a stroker, arp stud kits, full gasket kit ect ect and this is where i am today. In this build thread i will try and outline some of the do's and donts of engine building, a few bits and bobs on how to ect ect and by the end if it, ill show you how i have done the engine and gearbox removal, by myself, in my own home garage and show you the little tricks ive learnt along the way. Of course, pictures will flow on as i recieve the gear from brad and the engine machinists and as i get time off work to tinker ill try document it with my wifes new cannon 60D which i will endeavour to cover in grease and grime......
Cheers, Allan
https://www.sau.com.au/forums/topic/385122-homebuilt-rb28-gtr33/
Got the engine block back today and got straight to work on it. Drilled out the oil returns to 9.5mm, took a bit out of the larger oil return galleries with a die grinder and chamferred all the oil galleries. Then gave it a hell of a wash and a solid water jetting then gave it the mandatory wd40 bath before setting about installing the ARP main studs i have here from SPOOL. I can tell you all that the off the shelf kit requires the trimming of 2 studs. One of the rear studs and the centre stud(long one) as the rear hits the sump and the centre one hits the driveshaft tube. I did this with a 1mm wafer disc and a 5"Grinder and did it VERY slowly so i didnt introduce and significant amount of heat into them then reinstalled them. They require approximately 5mm removed from them each. With any luck i will recieve some oil pump gears next week along with some valve springs and i can start assembling the head.
Now, speaking of the head, i took the plunge and had a play with the exhaust side of the porting. I got myself a few cartridge rolls and a few buffing wheels for my dremel(not cheap, so small yet so exxy) and set about mainly cleaning up casting marks, blending in the bowl area and removing the exhaust hump and matching the ports to the Greddy Manifold i have. This was a reasonably time consuming process as it was a bit of cut cut check, measure check cut and so on as its something you wouldnt want to get too lax with. Anyway, the end results were pretty good and im happy with them, i got them all flowed so i could match them by my mates old man(sneaky bugger has a bench) and presto! I also had a small play with the inlet, i just blended the massive steps on the port where the cutter had cut the seats.
god damn gingerbeers lol
Im a TQ auto mech, but ive been out of the game for about 6 years so im a bit rusty, but its like riding a bike :P
I was gonna study to be an engineer, but then i thought to myself, hey....do i want to be hated by EVERYONE on a jobsite? Do i want to be looked upon as Different? then i thought ill go try something else...... lol. JK roy :) You meet some great ones, then you meet the ones that need to be hit by a stray comet lol
Its amazing how nasty the insides of the ports are, both with casting marks and machine marks. Good work on cleaning them all up mate! You can get the catridge rolls for cheap off ebay and from a few online american stores. Same with carbide burrs. Stuff here is so damn exxy!
yep. Bigmike, its the spool stroker crankshaft, piston and conrod kit they have listed on the website. Im pretty eager to get it going but also pretty sure im gonna have to be careful building it at home. Already run into troubles with the machine shop trying to tell me that its fine to mix and match stainless and sodium filled valves lol. Ended up replacing them all with stainless valves and went .5 larger.
Cheers, Allan
As you can see, there isnt a great deal that needs to be removed from the oil galleries. I have marked them in black mikko pen here on the left and right rear drainspost-35544-0-18294400-1324363357_thumb.jpgand post-35544-0-37646400-1324363383_thumb.jpg
and here is one side as im cleaning it up for reference. There isnt alot of material you have to remove, just that you have to do it rightpost-35544-0-78518900-1324363506_thumb.jpg
Here you can see the ARP bolts that need to be trimmed and why they need trimming. The first one is of the centre stud that interferes with the driveshaft.
and the second is where the stud interferes with the rear of the sump
Guess ill throw some progress shots of the home porting i have been doing. I didnt take any before shots sadly :(
ok, this is about 1 hour in on the first port.post-35544-0-69633000-1324364312_thumb.jpg
and then after a bit of cleaning up on the topsidepost-35544-0-61557600-1324364342_thumb.jpg
Its a simple rinse repeat process and it is pretty time consuming and also, a big thanks goes out to Gerg-R31 for his quick piece of advice on the porting :) cheers son
Had a billet oil pump gearset arrive today from Spool, thanks brad. Also had some new valve springs arrive from the same company but unfortunately my conrods and crankshaft will not be available until after christmas, you cant have your cake and eat it too :)
As requested, le snake. We get a fair few browns around here at home but this guy is just a tree snake. Very pretty snake and a good opportunity to teach the kids about snakes and why they shouldnt touch them or go near them
He was asleep on the drivers seat under the gasket kit i had resting on the seat. When i moved the gasket set he sure got the shrts on and wasnt too impressed at getting grabbed by the head lol. The wife lost her shit as usual at me for showing her close up and surprising her, but the boy loved him and didnt want to let him go lol.
Cheers, Allan
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
