Hi fellas,
It's time for a rim upgrade for my R33, so decided on a set of Volk TE37's with 4 x TE37 18 + 10.5+15 for a GTR in gloss BLACK.
I was tossing between a set of LMGT4's but decided on TE37's as I felt a 6 spoke rim looks nicer on a Skyline. What you guys think of these and where can I get a set of authentic Rays / Volk Racing stickers as the set I'm getting has the stickers but they're a bit faded.
Do you guys agree that TE37's look tough on a GTR?
DO YOU HAVE ANY PICTURES WITH THESE RIMS ON YOUR GTR?
Edited by Spunky Munky
  • Replies 91
the 37s look tough on most of the skylines in my opinion. Plus to anyone that knows there stuff there a real head turner and will be highly appreciated (followed by fits of jelousy over not having a set for themselves :P). good choice man, the lmgt4s would of look tough also...
I'd give the go ahead with either LMGT4 / TE37.
On The Run Motorsport are based in Melbourne and they sell the genuine 'Repair Sticker Kits' if you want new stickers for TE37's.
And they have the choice of Black / Blue / Red Sticker Kits to match the correct TE37 wheel.
Yeah I agree with you mate - the TE37's are probably the nicest rims to ever come out of Japan followed by the LMGT4's...they look good on all Skylines for sure...loved how you describe people's fit of rate when seeing them...for like $4.5K brand new I guess there is some logic why most people would choose not to go ahead with a set and rightfully so too...but I'm lucky, going to pick up a good set for $2.5K. What you think of this price range?
Thanks mate.
Much appreciated bro - great info will definitely need a set.
Thanks.
Post pics when done!
For sure mate...
HEy what would be the best tyre profies?
Front 235/45/18
Rears 225/45/18
Also, does anyone know what the legal amount of tread remaining on wheels are in VIC? The rims I am getting will come with 50% tread left on all 4 rims - is this still legal? With the money I spending, don't want to spend more cash on tires until a few months' time.
Thanks.
For sure mate...
Front 235/45/18
Rears 225/45/18
Thanks.
you do know that those tire sizes will be very stretched on the size of the rims you want.
For sure mate...
Front 235/45/18
Rears 225/45/18
You might want to put the wider tyres at the rears.
Like what JnJ said, it'd be stretched, with 18 x 10.5 so you might want to go at least a 255.
Preferably run all same size tyres all round.
Thanks.
50% is fine, as long as you are not down to the indicator mark.
But I would be buying new tyres anyway.
Shop around and compare prices.
Tyrepower Hawthorn / North Melbourne and On The Run Motorsport can all do good prices on high quality tyres.
Thanks matey.
Appreciated it muchly.
  • 1 month later...
275/285/295 is ideal.
265 is a bit more common, therefore a bit cheaper, so people tend to buy them. Just a cycle.
Just like 235/45/17s, commonly used and cheap in most brands.
Volk TE 37 Superlaps on a Midnight Purple R33 GTR? Thoughts or pics of one??
would look very good. i just recently fitted matt black rims to my mnp r33 gtr n looks alot better than before in my opinion.
do a google search and some images should come up of the sl's on a gtr.
i will be putting some new photos up in the photography section once my abflug rear diffuser arrives from japn
also pretty sure that sunline racing used to use those tcII on their carbon r34 so they must be pretty good if a high class tuner in japan would use them for a time attack car
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
