Will be using 2x400lph walbro pumps in my surge tank the new e85 set-up.. Can't give any feed back on them yet though the fella who's designing and building the tank reckons they are an awesome bit of kit.. Very well priced as well
I have a feeling I'm only going to need to run one pump though :D
  • Replies 49
I installed the E85 one in tank in my Gts-t RB25
All is well so far, tune in a few weeks. Easy to install, sucks a lot of power so make sure you have the appropriate wiring
Hey mate, i have one on the way. what did you do to beef up the wiring?
Slighty OT but im wondering if anyone has done anything to bypass the stock plugs intank on the lid?
I usually rewire the intank portion aswell as adding a relay and feed from the battery but it annoys me reusing the stock plugs and crusty old wiring to get throught the lid.
I added 2 posts with 5mm stainless threaded rod and a series washers and nuts to come through the stock plastic lid in a 33gtr. To seal it i used injector orings bellow the bottom washer and applied some pressure when tightening the nuts down. Could be worth trying RS components they might do a proper bulk head fitting to do the same thing.
I hope your upgrading your alternator if you plan on running 2 of these.
Hmmm will need to figure out the current draw for each pump and go from there.. Like I said I'll probs only use 1.. The other one is in there because the tank is a proto type and we wanted to run 2 to see how it goes
By my calculations one on 13.5V is enough to feed 1000cc injectors at 25psi boost (assuming base pressure of 3bar)
Considering that we usually run a touch higher than that voltage on our cars, they should be good for a bit over 600rwhp (on a Dyno Dynamics) on E85
At the following pump pressure on 13.5 volts it draws the following below, so double that if running 2 pumps. Thats a lot of current draw, even 1 pump is a fair amount of current draw.
at 50 psi - 14.88 amp
at 60 psi - 15.64 amp
at 70 psi - 16.45 amp
Edited by slippylotion
Righto cheers lads, I've messaged the guy whos putting it all together. I assume he's already figured all this out but it would be good to know how's it's going to peice together.. Will report back once I have the solution/ or when car is up and running
My bad, I'm talking about the big E85 one the F90000267 so it flows even more and also needs more juice to run... Mine should run about 18amps under load.
I have run 25amp wire, a 30amp circuit breaker and relay to mine so I should be ok. The only issue (as someone else has mentioned) is the stock lid of the fuel tank
circuit breakers are to protect the circuit, if youre running '25a' wire, your breaker should be under the rated cable size.
  • 2 months later...
bumping an old topic,
hows everyones walbro 400lph holding up so far with E85?
also came across a newer "450lph" e85 version, any opinions on these?
http://www.ebay.com.au/itm/Walbro-450-LPH-In-Tank-E85-High-Pressure-Fuel-Pump-Install-Kit-F90000267-/150845458543?pt=AU_Car_Parts_Accessories&hash=item231f17086f
im assuming from what ive read here the 400lph one would suffice for around 380rwkw on e85?
Walbro F90000267 (416L/hr E85 rated one) tuned yesterday on my Green Gts-t...
No signs of running out of fuel and the 1200cc injectors were showing 75% duty which shows they can pump at least enough to outflow 900cc injectors (and should do a fair bit more). Fuel pressure was around 70psi on boost
Cheap, nice and quiet, easy to install. Only downside is they suck a lot of power so just make sure your wiring is up for it.
I would recommend these for all in tank installs instead of Bosch 044/040 or Nismo etc
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
