Ive been looking for something like this thread for a long time! its exactly what a skyline needs if your running a pod, that cold air is quite important!
But, isnt it illegal to drill that hole in the position where you did? (So ive been told) I have two 3" holes in my 32, currently occupied by the intercooler pipes confused.gif but it would be nice to get some sorta setup working in there before my next tune
thanks everybody for all the help and ideas! thanks brett i checked with vic roads to, any mod to your car under your p's is illegal pinch.gif im just gonna go ahead and buy a panel filter instead, looking at the nismo s tune sports air filter
From what i have read on here i would not waste your money on a nismo filter, saw a test on here ages ago that showed the factory filter is the best one available, at best i would (and do) use and non oiled k&n and im making 250rwkw so that will be more than fine in a non turbo.
The car you are driving is illegal for a start.
Just get a K&N panel filter.
Good enough for me @ 365rwkw, good enough for you. About $80-$90 or so. You could probably find cheaper if you shop around
The GTR airbox & snorkel design is much different to the GTST one, the GTR is much more free flowing. What works for a GTR will not always work for a GTST/GTT. Best thing to do is probably put the car on the dyno, get a baseline run with the standard airbox, snorkel and filter. Do another run with the lid & snorkel removed, then another with the filter out. This should let you know if there is a restriction there. For a GTST/GTT I would say the answer is yes there is a restriction. You can always try and put in a new filter with/without the lid & snorkel and see if that makes a difference. I have heard that the standard Nissan filter is quite good for flow. I am thinking of using these and replacing them regularly like I would copper plugs. Standard Nissan panel filter is dry too so no oil on your AFM.
A pod should provide you with the best flow as with the right one the surface area will be much larger than the panel filter. Not to mention the base of the airbox in the GTST/GTT blocks a considerable area where the AFM bolts to it.
LOL sorry mate i didnt mean to say gt 't', its a gt 25 non turbo. really i find it hard to believe how a panel filter that can be bought from autobarn is better than something made by nismo specifically for japanese vehicles, but if everyone is saying K&N then i guess ill go with it!
Yes i realise that.
But on a bog stock (what we thought was a gt-t), it's fine. A gt-t airbox really isn't that bad if you have a look at one. They are a good piece of kit. Hence people make 270rwkw through them with nothing more than a replacement filter.
Now it's a GT - even more so unimportant.
Just to make sure.. I wasn't having a dig, just wanted to mention some observations I've made with a lot of looking at the standard airbox setup for the R33 GTST. I believe the R34 GTT is nearly the same apart from a slightly different snorkel design. I did buy GTT & GTR ones at some point in the past to see if I could use them instead. I did not. I have had the airbox lid removed at a 200rwkw level and it made a noticeable power change and altered the Air/fuel ratios, so it definitely changed things. I have modified a standard airbox quite a bit and it still didn't make any huge improvements so I am going to look at some alternative options.. :ninja:
I'm pretty sure Stao and others found the airbox a limiting factor and had to cut holes in the lid to flow enough air.
As mentioned though, being a GT, it's not going to change much in this situation.
Ye - on a dyno with the bonnet up :)
Take it out onto the street where the airflow & snorkel are working how they were designed and it's a different story. Dyno fans really don't have the same effect as travelling @ 80-100km/h+
There was a graph about 2yrs ago with back to back. Difference was around 6-8rwkw IIRC on the rollers on a 250rwkw setup. (R33 gts-t airbox it was, using a K&N Filter). Difference ye, but it's not major and certainly not worth the undue hassle you end up with. Depends on the person if they cbf'd with doing a proper CAI setup (that is still illegal).
LOL.. yeah there is definitely more to it than simple lid off :)
What gets me a bit is the 'cooling panels' that people put over their grill in front of the radiator support bar. These basically block the snorkel flow.. I did start to muck around with fibreglass one that had the snorkel sit sitting low but didn't end up finishing anything.
<br />LOL.. yeah there is definitely more to it than simple lid off <img src='http://www.skylinesaustralia.com/forums/public/style_emoticons/default/smile.gif' class='bbc_emoticon' alt=':)' /><br /><br />What gets me a bit is the 'cooling panels' that people put over their grill in front of the radiator support bar.  These basically block the snorkel flow.. I did start to muck around with fibreglass one that had the snorkel sit sitting low but didn't end up finishing anything.<br />
<br /><br /><br />
Depends on what diverter plate and what car. If you have an R32 GTR bonnet and grile, the diverter plate sits below the top grille bar and so air goes over the top of the grille into the snorkel space. Which would be great if R32s had a snorkel!!
I'd be wary of using an oiled filter on an engine that runs a MAF (and a 10+ year old one at that) due to the possibility of oil getting onto the AFM wire. I also would not be cutting holes through metal for that ghetto CAI mod (which incidentally would likely not work with an open pod anyway)
the stock airbox dosen't look that restrictive TBH, pity no one does OTR intakes for Skylines haha
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
