My car sometimes, not all the times, hits about 500rpm when clutching in. It doesn't sound like its going to stall but it doesn't sound like it should be doing it. I have a fair bit of bolt on mods with the PFC ECU. Sometimes when coming to a stop(and it makes no difference, off boost, light throttle etc) the revs come to about 500rpm and the car kicks back up and idles fine. Ive cleaned the AAC. Ive removed fuel from the cells it hits in the first column of the pfc but didn't make a difference. Its going into the first column then into the higher load cells. Something is telling the car there is a load on the engine and it kind of f**ks around a little...
Also, now don't anyone give me shit for it, if I want to remove my BOV, how do you tune out the symptoms of running no BOV? I know alot of cars who have no BOV with nice deep flutters and there car doesn't stall. My old skyline would switch off instantly even on a free idle rev and flutter. Is it about removing fuel or giving it fuel?
https://www.sau.com.au/forums/topic/387111-how-do-you-tune-out-flopping-rpm/
There is no way to tune a PFC around maf reverse caused from running no bypass valve. All you will be doing is fudging one section of the map to stop overfilling of another section of the map.
Ie you may help the idle sag but create a lean spot once on throttle. If you want your car to be in a proper state of tune put the bypass valve back on the car and get over it.
But Ive seen and heard of a fair few skylines running power FC with atmo bov and even with a blocked BOV and some don't have the issue...
Gay piece of arse AFM.
None the less though I still get the dip in RPM WITH the BOV fitted. Like I said in the OP, I don't even need to be on any boost(all vacuum) and it still does it. Just now I was driving home 50km/h in third. I clutch in to stop at the lights and they dip to 500rpm then jump back up, it just gets worse with the BOV gone.
Edited by SargeRX8
IAC and AAC are the same thing just different names.
No, not true. IAC is the one on the back of the plenum that the ECU controls the idle speed with. The AAC is the Auxiliary Air Control which is the heated thermostatic valve hidden under the plenum that is open when cold and closed when hot and allows a lot of extra air in to raise the cold idle.
The only one that matters in this instance is the IAC, but if he's cleaned it and it still fluffs around then it is probably a tuning issue as per others above.
I cleaned the aac as per the diy. Is that cleaning the iac too? Afaik the aac lets the engine breath more air when you use things like air con, the brakes, power steering etc.
Isn't that thermostat the csv, cold start valve which is the one under the plenum?
Edited by SargeRX8
Ah i see now. So the AAC is what i was calling the cold start part of the system and the IAC is the Idle control. i always knew that's what the IAC did but people always throw AAC around and gets confusing.
Yeah that's fair enough then. at least that clears that up
I changed my FC/1 and FC/2 settings and mine is fine now. used to dip a bit when clutching in and IAC has already been cleaned. set them at 1500 as suggested
Edited by 89CAL
good to see your being as helpful *cough*condescending*cough* as ever mafia.....
Will adjust those sells by a few degrees, +5 should be fine in each cell right?
depends what they are at the moment. i wouldnt go any further than 20-25 degrees in n01 as any more is likely to go backwards and have the same effect as less timing. unless your timing in these cells is really low for some reason this will just help to mask whatevers really causing it. its sounding more and more like a sticky iac/aac
its abit hit and miss as that rpm range canot be acuratly "dynoed" i find wacking in some timing and similar fueling as at idle seems to help. also having a blanket 20 odd degrees around the idle area seems to smoth out a unstable idle. bigger afm,s and non return bov's do make it harder.
also raising the decel fuel cut to around 2k helps aswell. on our race car it has no idle control at all. and used to hunt real bad after giving a rev. when i turned off the decel cut it was perfect.
The decel fuel cut not cutting out soon enough could be the issue.
20 deg of timing around the idle is a fair bit. I run 16° at idle, 12° at 800rpm. Also 13.8 AFR 1200rpm and below. Good for clutch out at idle in traffic - crawl.
the only suggestion i have is find someone with datalogit, copy your tune
get the engine setup correctly, base timing, remove your bov or fit it (how ever you like), check the aac valve, check idle air control, check for basic vac leaks etc
then DATA INIT
perform self idle adjust as per powerfc-faq
and let iet idle for 30 minutes (dont drive or f**k around, just let it idle as per instructions)
then confirm you have good idle and stable de-accel
ie go for a fang around the block and confirm its OK
then "write" your previous tune over the top
if you dont have access to datalogit its a bit painful to do it manually
ie pay someone beer to copy your tune
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
