NAPREC RB26 FORGED VALVE HIGH RESPONSE HEAD
This head was fully checked and by HKS Japan before being sent to Naprec for machining and has process of Naprec High Response kit which is worth close to $2000 alone.
Perfect opportunity and great base to get the head port polished to your specs and your choice of cams and valve springs and have a mean race or street head.
Great opportunity to get an awesome RB26 head that has been machined by probably the best engineering company in Japan.
Head has had the following done.
http://www.naprec.co...6/hrk_rb26.html
http://www.naprec.co...26/0605_04.html
http://www.naprec.co...26/0605_01.html
I'm selling this as was a spare head I had built in Japan by Naprec & HKS and no longer needed
I'm chasing $2300 buyer to pay freight postage (weighs 19.5kg packed and head is on the Gold Coast and willing to ship anywhere including Timbuktu)
Dude why must you temp me.
Tempt away !! :thumbsup:
You know you want it !!
Damn I just finished my build!! I would of taken this!!!
Only got back from Japan just before xmas for a couple of months of Aussie summer, Bbq's and beer and was waiting until I got back to put it for sale.
Can vouch for Marcus being an awesome guy to deal with and always has the best stuff for sale too thumbsup.gif
Excellent piece of kit by a superb seller!
If only I havent this much debt...
Cheers fella's
Debt is just another word for must buy !!
Surprised this hasn't gone yet!
Too cheap Marcus!
Yeah I know Paul but need to get rid of parts I dont need anymore.
If I dont sell it soon I might keep it and build a RB30 engine for it or put it away for a rainy day.
hmm maybe i need to build a 26/30 instead of a 25/30 lol..
buy his stuff now!
its actually easier to build a 26/30 than to build a 25/30 all u need to do is re-drill at tap the head stud holes in the block to make up for the larger gtr head studs, all the oil galleries and waterjackets line up, on a 25 you need to grind out the galleries and jackets to line up with the 30 block
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
