  • Replies 131
Will be running a 6boost twin scroll manifold.. I'm not to fussed about the exhaust housing size, with the head mods and dual wastegates ect. I think it'll come on boost the same as my -5's...
Hey guys, Sorry I said I'd update this on the weekend, but I guess I was just lazy/to busy trying to put this engine back together...
Okay, so I have finally picked up the engine from Tony and it looks great!! :wub:
The only issue is that the drain at the back of the head isn't one of those alloy block ones, it's just a areo fitting bent into a 90* bend. It's probably a 5" diameter bend so it's going to need to be changed for a smaller one so it will clear the firewall..
Engine
Sump
Exhaust Port
Intake Port
I took the engine over to BoostWorx thisarvo to get put back into the car.. On my way there I picked up a new Xtreme Carbon Twin Plate Clutch with Cromoly Flywheel so now it will be able to handle the 450awkw that she'll be packing haha :3some:
Cant wait to have her back!!
Hey guys, picked up the turbo and manifold today do I'll post up pics tonight, looks sexual haha
Everything is coming together..
I need a bigger fire place so all the cash I'm burning on this will fit hahaha
Hey guys, sorry I haven't updated in a while, I've been busy moving house and trying to organize this thing at the same time haha..
Well, I went over to BoostWorx yesturday to have a look and I must say what an excellent job they have done, the amount of work they have done in the last two weeks is amazing!!
Engine is in, turbo is on, clutch and all fluids are done!!
So while I was there, it was time for the first start up.. Always an exciting time!!
The engine turned over, and over, and over but didn't fire... Just a few splutters from the exhaust!
Turned out the the insert to be pressed into the front of the exhaust cam to turn the cam angle sensor wasn't installed from CamTech.. This ment the senors wasn't turning and the timing wasn't ever going to work..
I got straight onto Tony to see what we could do. He called CamTech and sorted out a R32 insert to go in and a R32 cam angle sensor, should be here today and 11am. Hopefully, the car is started and a basic tune done by this arfternoon :) WIN!!
I'll post photos of the engine bay and progress tonight..
Wtf was that... Damn iPhone.
Can't wait to hear your result Brad
Yeah cheers mate, can't wait to get her back on the road, hoping for 450awkw on E85.. Should get there haha
Soooo, quick update!!!
Engine runs!! However, there is an oil leek at the front crank seal and also a little one at the rear main seal.. Engine is literally brand new so must have been a kink in the gasket when it was put together or something..
Shaun is fixing the leak this week and is going to bed the engine in on the dyno next week.. Can't wait to see some results
  • 3 weeks later...
Hey guys, so today the engine ran properly for the first time..
It ran for 40kms doing some basic bed in things and then got its run in tune;
279kw @ 9psi 8000rpm
Boost pulls as early as 3000 rpm!!
I'm so happy with the figure, it's more responsive then my -5's on my standard motor... With E85 and 28psi I think an easy 500awkw is achievable..
Who ever said you can't have power and response??
Cheers
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
