ANG Automotives
1/10 Malland St Myaree
93173025 (bookings required)
This is a private workshop. The guy who runs it (Angelo) is easy going and takes a common sense approach to things. Unlike the robots at the licencing centres.
Good luck!
https://www.sau.com.au/forums/topic/388737-yellow-sticker-take-your-car-here/
  • Replies 40
You'll actually find there are a few mechanics who can do this:
http://www.transport.wa.gov.au/licensing/21360.asp
I personally used Pebco to examine my R34 GTR, they were decent blokes and happy to help with instructions on how to fix any issues.
As well as allowed me to drive away, fix said issues and come back with no extra cost (on the same day).
Great for minor issues that would normally call for a full re-inspection at the pits.
Edited by j3rk
I got a sticker on my car last night, Will give these guys a try.
whats the sticker for?
I took my v36 there to get WA rego. The compliance shop didnt change over my HID globes before that. I told him straight out, but my car still passed.. Good bloke!
Moral of the story, as long as you dont go in with something obviously illegal or unsafe, you probably have a far better chance with these guys.
Also, in the event that it doesnt pass, they are a mechanics, so they can probably help you change/ fix things in order to pass. Saves you running from the licencing centre to the mechanics all day long wasting your time.
This new system should have been set up years ago. I think the original idea was to ease the back log at licencing centres from all the hail damaged cars coming through.
Edited by projectx
ANG Automotives
Good luck!
I have just moved to WA from NSW and need to get the rego transferred and will need to go through the inspection process because the car has a fair few mods, however nearly all of the modified areas of my car are only just out of specs according VSB's and regulations.
So how do they go with suspension heights and wheels diameters etc. that are only millimeters off what they should be legally?
Are most places anal about these things?
Licencing centres are anal about these things, if you catch them on a good day you might get lucky. Catch them on a bad day, and forget it. They will write a list of crap as long as your arm. Once that stuff has been recorded, it will follow you around no matter which place you try and reattempt it. After that, they cant just turn a blind eye anymore if you know what i mean cause its on paper.
Got the sticker for a shit load of things.
Atmo bov
No emission control
Screamer pipe
Pod
Tint
Wheels sitting a inch outside the guards
tint
There more but i cant remember it off top of my head. Meh.
Atmo bov
No emission control
Screamer pipe
Pod
Tint
tint
I went there and got raped. Defenately would not recogmend going there. Better off at the pits.
I got picked on every little thing and he wanted permits for everything..
DO NOT GO HERE
Well if you went with the above list, I'm hardly surprised...
There is no advantage in going to those approved mechanics if anything the pits might be better due to rushing. I had my sticker off at pebcos after second attempt. They failed me for my head lights being to dirty and the tint. The time before I went to pits and passed with ease they never even said anything about the tint. Pebcos spent over an hour on the car. The approved mechanics go over it more than pits.
The only advantage is the experience. The Pits suck for that.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
