yep 3040 (3082 in new terms) is way too much compressor for a gt30 hot side.
if you already have the gt35 and can easily get a smaller rear then that would obviously be the easiest and cheapest option. a lot of people seam to get good results with the .63 gt35 which is strange because its a bit of a mismatched turbo. personally i'd prefer a larger housed gt3076 but each to their own.
just keep in mind, even if you get similar results the larger reared gt30 will be easier to drive than the .63 gt35, it will come on more progressively and make traction a lot easier
I reckon it should be fine mate i have a GTX3071 with .82 internal gate made 288kw @ 21psi without boost control issues im now at 307kw @ 18psi with 25psi coming soon. YAY! Just make sure u dont use 1 of them dodgey divorced front pipes
so im thinking about getting the GT3076 with a internal wastegate .82 rear i wonder if that will be ok for 290-300rwkw without boost problems
What boost problems? It would have to be THE most common turbo on an RB25DET for an obvious reason. There are countless 3076s with internal wastegated 0.82 rears making 290-300rwkw. If you choose the GTX3076 they seem to respond well to higher boost levels above 20+psi.
But geeze looking at NYTSKY's thats a lot more top end with the 35! I know it has a lot of other mods and a fresh engine etc but if your after a car to break traction and do naughty things then its quite a good option. But if your after an all round fast car with linear power/torque then GT30 it is.
yeah i just sold my gt3582r today for 1500 and im looking at 1480 for the gt3076 with the 5 bolt internal wastegate .82 rear just not to sure what todo about a dump pipe as i wont be able to drive it to the exhaust shop
oh i though people had problems with boost control i must of misread something hahaha but yeah hopefully with 290-300 the gt3076 will still be naughty hahaha
Is it true that nowadays the Garrets are costing as much as or less than the Hypergears, which are not a fully bolt on either.?? Re: custom intake, 90deg elbow, water lines etc, the only thing that bolts on in the HG and not on the garrets is the dump. Hence makes a lot more sense to go Garret..Or did I miss something..
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
