Unfortunately my headgasket started leaking about 3-4months ago, was making 302-308 rwkwk on 19lb on 98. Fixed it in a couple of weekends, Put new nissan headgasket and head bolts. Aiming for 340rwkw and up on e85 :) Anyways here's how it looked when i cracked open the head!
With that cylinder pressure I would be swapping out the factory head bolts for some ARP 625+. Your call at the end of the day... Perhaps you enjoy changing head gaskets. :P
Doing jobs like that is my occupation. If she shits a gasket ill put a mls gasket and uprated head bolts or arp studs
Edited by LTHLRB
  • Like 1
Are you another Kiwi? We only have E85 at two pumps in NZ that I am aware of. There are guys who bring in Sucrogen E85 (works out as like $3 a litre) and we've used this on flex fuel cars: http://www.trademe.co.nz/home-living/cleaning-bins/other/auction-634702052.htm
I've got a spare motor, things never break when you've got a spare :D
E85 is still hard work in NZ
Looks like i gotta put a spare short motor aside and wind the boost up. Test your theory
Yeah, still only the two pumps. Taupiri Auto Store have drums of Gull E85 which works out around $3 a litre too, may end up having to go that way
  • 1 month later...
Standard unopened RB25DET Neo 150xxx K's
Hypergear ATR43SS2 internal gate
Standard exhaust manifold
Standard intake manifold
RB25 S2 throttle body (deleted traction control and cruise control)
3"JJR Mild steel bell mouth dump pipe
3" straight through exhaust (no cat)
R32 GTR intercooler
Xspurt 1000cc injectors
Standard fuel rail with 4mm spacer
Greddy Profec B spec II
R34 NISTune ECU
Pic to come soon.
R32 GTR intercooler
R34 NISTune ECU
Pic to come soon.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
