Car does daily duties on this set up > http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-42
And the above for a drag day.
Notice the backend was changed and also no WMI is used alongside the C16 as it kills the power. Afrs are around 12.0 so injs have a little room still.....and so does the turb :yes:
Havent sorted the suspension for it to hook and put down an Et yet tho.....
my turbo has no antisurge and stock airbox...there is no whistle
actually apart from exhaust noise there is nothing
poor Bast#rd!! the whistle is awesome, get the cover and fill the streets with some RB 3076 whistle!! Edited by AngryRB
GTX wheels have quietness as one of their design targets - they are intended for industrial etc use, one of the reasons why some of the more high performance targetting (ie, EFR, HTA) potentially will have the edge in other ways over them, as response/wide & tall compressor maps etc are the intentions.
I'd take a closer look at a "GT3076R" with a T04S compressor housing on it , just to make sure that it has the GT37 compressor wheel in it .
I'd want the HTA wheel if I was running that housing or something that performed similar to it .
Does anyone know if Tao at Hypergear is doing cold side upgrades to GT30 turbos ? I'll ask this in their thread too .
  • 1 month later...
Standard re built S1 rb25, pon cams, ex cam gear +8, walbro 460 highflow standard side feeds 740cc, power Fc, hks gtrs kit, blitz fmic, gtr itbs etc etc
United E85
Royal Purple 10w40
Street driven soon to be tracked
303wkw @ 20psi
Massive boost leaks and 4psi back pressure at 20psi at O2 sensor port and clutch issues... All to be sorted next weeks and a retune with new eboost2 controller
I don't think you know what unopened means bro
I know what unopened means 'Bro'....... hahaha i read the title and my head automatically interpreted it as 'standard bottom end' lol
anyway whatever haha we all make mistakes :P
Edited by LaurelPWR
Still good power out of a gtrs. Lag must be non existent almost
Nah man its a little lagy hey....... as i said earlier, tons of boost leaks and some other issues haha soon to be all fixed :D
check it - http://www.skylinesaustralia.com/forums/topic/441053-should-my-hks-gt-rs-be-making-boost-earlier-e85/
relax man just having a stab. Those results seem pretty good for a gtrs on 20psi with a whole heap of boost leaks to the point where it feels laggy. I wonder how much the cams helped that figure. Also do you have vct? Might be a factor in the laginess you're experiencing
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
