  • Replies 71
Nothing has been said that is untrue or potentially untrue.
They fixed a tune that Croyden could not on my car, just to balance things out.
I'd definitely say the above quote is derailing to their business, and unfair. While I don't doubt the "truth" to it - he's effectively saying that's what WILL happen if you take your car there. Who would take their car to a place when they're assured it will take 6 months to *not* fix?
If I were Shell, I'd edit that shit out. Trojan, while they haven't done any serious work to my car, have been nothing but helpful when I've dealt with them. Great guys.
+1 for sure, been able to find parts for me that other places weren't able to.
i have been using Trojan for past 3 1/2 years and they have been awesome it is a two man team so the can take longer, but i the quality of work is some of the best i have seen. i personally have found that places that finish work fast on modified cars, cut corners i had it happen to me on at least 3 separate times.
I think anyone with half a brain can see he's referring to his car, and you won't be assured of it taking that long :laugh:
But if you're going to join the butthurt brigade about it (just on the other side) I will go and edit it ;)
This is by no means a derogatory statement as ive used CRD in the past and was happy with their work but bring ya $$$$ with ya mate as they know how to charge
They want too much to check over what I want. I'm just going to save up and head down to either CRD or Race Pace.
My uncle has recommend CRD and race pace. Considering he has raced heavily modified r33 gtr race cars :D. Better to take his advice.
That's partially my point. Your uncle has cars with big build, big power and in turn.....big money. Unless they're going to be doing a considerable amount of work on your car, or they expect your car to be good publicity for them, I wouldn't expect CRD to particularly give a shit about you. It's all business, and to them you're just the next nobody. Doesn't mean they'll do a bad job with your car, I just wouldn't expect the same treatment or for them to look after you too well.
Troy don't judge on what you haven't seen either.
Most places will gladly take your money for big or small jobs.
Sometimes it's worth just paying once to have something done right.
Can also tell you from experience that CRD are no more expensive than getting work done locally. Have plenty of receipts to prove it.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
