My first PI track day yesterday, I managed a 2.03 lap. Hoping to better it next time as the car was on low boost.
I had a great time, hitting 250 up the straight was a blast. :)
http://www.natsoft.com.au/cgi-bin/results.cgi?21/07/2012.PHIL.S18.Y
  • 5 weeks later...
ive been searching the forums and havent come with an answer how much awkw does a stock rs4 stagea make? ive been told 110awkw
im intrigued as i see a lot of people with big power and am wondering if this rwkw or at all 4s because huge power increase if its from 110 to 260 with minimal upgrades on 98 pump fuel and when i say minimum i mean stock bottom ends and bolt ons especially high flows.
i just upgraded the turbo and nistune and on the rd it pulls hard strong midrange, heaps responsive but on the dyno it produced an average figure but strong torque which i cant complain about.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
