  • Replies 167
Posted Images
Hi all
I would also like to thank everyone for being so nice and tolerant of me and the big blue taxi. I've always wanted to have a go and this time did it. What a hoot! Absolutely stuffed by the time I went home. Thanks for the organisers they did a great job. I would certainly like to tag along again.
Cheers
Geoff
hi guys just got around to working out how to use photo shop
here a a few of my favourates and a link to the rest, unfortunately i didnt have my camera till the afternoon so all are from the battles
http://s1077.photobucket.com/albums/w478/r32-26tt/texi%20feb%202012/
Oh and these are low quality, I have much higher and larger images
Hi all
Cheers
Geoff
You're absolutely welcome again at future ones!
Thanks mate! They look great!
Guys (and girls), whatever Steve-O says about the Sutton Road facility, I can vouch for - it is an AWESOME venue and will be worth every cent you spend to attend and drive at, even if we can't bring the price down much!
Be warned, though: it is a fairly narrow track with some areas that don't have too much run-off, so if we do end up placing witches hats down on the track to keep the speeds down in certain areas, don't despair because we want people to have fun WITHOUT the risk of getting hurt and damaging cars. Oh, and there were kangaroos down there when we last ran an event there a few years back, which made us pause between runs on occasion because there's not much you can do to get them off the road sections.
Back on topic, once again a MASSIVE THANKS TO ALL OUR VOLUNTEERS on the day. It gave us Execs a few quick chances to get out there and enjoy it as much as you all were too.
Yes, thanks for giving up your afternoon runs to time Nick.
Soon you'll all be seeing a new project I'm working on to automate the timing (still design phase though). More details will be coming soon.
As always I'm slow to respond, kind of like sunday.
Awesome day, thanks to everyone helping to put on another great day. Thanks to Nick for giving me a race at the end of the day. Great to see a bunch of stags out there, now we need to get them on the skid pan. Hopefully my granny driving will encourage them to uphold the stag honor.
Sutton road looks great, very keen for that.
And Steve-o I drive faster when the icecream is melting.
Sorry guys, Presidential duties (like maning a BBQ for 3 hrs) wore me out so I didn't have the time to do the normal videos.
This is the price of being the man in charge. At least you I know you miss me :)
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
