Hi :action-smiley-069: , after much deliberation i have decided to part out my 1990 R32 GTR.
I imported the car back in 2005.Its been sitting in my shed for the last 7 years and travelled approx 2000 klms in that whole time so some parts are still "as new".
It has some worthy after market bits on it, some of which were on the car when purchased & other bits i had added on over time.Some bits i bought brand new from nissan and i have reciepts for all purchases.
The engine is not available for sale at this stage, either is the TE37 supa laps that are pictured on the car.(keeping these for somthing else)...
The car is not damaged in any way,i just pulled the engine out and since then, i have gone in a different direction. So parting the car out is the only way ill recoup some hard earned $ back that i sunk into the car.
I have tried to list everything in category"s so it makes it easier to find what you are looking for.I have also taken pics of the interesting bits. If your require pics of anything else let me know. Contact info is at the bottom of the list.
*** I COULDN'T LIST EVERYTHING ON 1 PAGE SO THERE IS MORE PARTS LISTED ON THE PAGE BELOW THIS ONE****
_EXTERIOR_
*Genuine ganador mirrors (colour black) fits r32 gts-t as well. $350
*Factory standard mirrors (gunmetal colour) pair- $100
*Factory bonnet -$450
*Bonnet hinges pair- $65
*Gtr Bonnet catch mount.This is needed if you are doing a gtr bonnet conversion on a gts-t (bought this new from nissan)-$90
*Guards left & right each-$275
*N1 front bar with factory fitted vents & lip-$575
*Nismo N1 side skirts genuine left & right set (6 pieces) new from nissan $1275 per side! I want for the pair-$500
*Genuine grill-$135
*Front rio.Has been neatly modified to fit an intercooler up to 120mm thick-$120
*Rear bar-$150
*Rear rio-$150
*Rear taillights pair- $150
*Reverse lights pair-$100
*Boot with genuine N1 lip/factory rear wing-$250
*Headlights,has brand new phillips 4000k bulbs fitted (high & low beam) so they are legal.($150 worth of bulbs) Headlights including bulbs pair-$300
*Indicators pair-$150
*Fuel flap-$70
*Wipers 2x front 1x rear (bought these new from nissan) whole set with blades-$125
*Front wiper motor-$45
*Rear wiper motor-$45
*Plastic cowling (located under front wiper arms) i bought this new from nissan-$65
*Doors,no windows,no window mech,no switches,NO INTRUSION BARS FITTED,includes door handel & lock each-$200
*Window mech left & right side each-$125
_GLASS_
*Left & right door glass each-$150
*Quarter glass each-$125
*Factory windscreen with built in aerial-$300
*Factory rear glass,Gtr is lighter as its 3mm thick compared to Gts-t which is 5mm thick-$400
_INTERIOR_
*7 point roll cage,safety 21 with full padding.comes with all nuts,bolts & 5mm thick stainless plates for mounting to the floor & rear wheel arches-$750
*Factory Gtr steering wheel in RARE mint condition (see pics) with factory Gtr horn button-$395
*Factory front seats in mint condition-$600
*Rear seat,1 small cig burn but can hardly see it-$175
*Door trims in mint condition,full set front & rear-$400
*Drivers side window switch-$125
*Passanger side window switch-$55
*Roof lining-$90
*Interior light (front)-$35
*Interior light (centre)-$35
*Rear vision mirror-$85
*Sunvisors pair-$60
*Carpet exelent condition.I had roll cage installed (only rear section of cage was fitted) carpet has been cut so there is a flap that hides where cage was mounted.-$150
*Boot carpet is in immaculate condition as i bought the main floor piece new from nissan.Complete boot carpet-$250
*Boot wood pannel that covers the spare tyre.No worps exelent condition-$65
*Space saver,never used-$60
*Dash pad,no worps,no bubbles,no sun fade.2 small screw holes where a gague was mounted (see pic) very nice-$250
*Centre dash vents,i bought these new from nissan-$95
*Passanger side air vent bought new from nissan-$65
*Glovebox with lock-$75
*Factory digital clock with sourounding dash piece (clock was working last time i checked) $125
*Plastic underneth clock asslemby (plastic that hides under dash wiring) like new-$55
*Kick pannels left & right,each-$20
*Centre console (arm rest piece) with rear facing ash tray.Lid is like new-$90
*Console piece that fits over the top of centre gagues and holds ash tray,This piece is the rough texture (off a 1994 v-spec r32) comes with new Nissan leather gearshift boot-$110
*Console piece that holds the stereo,ac display & centre gagues,looks like new $95
*Ash tray with nismo shift pattern sticker on it,like new-$35
*Factory ciggy lighter never used-$15
*Plastic steering wheel schroud-$25
*Indicator stalk-$55
*Ignition and genuine Gtr key-$150
*Rear parcel shelf good condition-$65
*Factory jack & tool kit never used like new,both $100
*Japanese front seat belts pair-$80
*Japanese rear seat belts pair-$70
*Drivers side stalk that holds top of seat belt-$50
_SUSPENSION / STEERING_
*Quantum T5 RS Stage 2 Coilovers,i bought these new from Japan at a cost of y359,000 !! These are high end coilovers as used in alot of race cars throughout the world.Including many Japanese race teams have used them as well as European race teams and you can find these on alot of Porche's.These have travelled around 2000 klms and are still like new as pics will indicate.
Pillow ball tops spring rates are circuit spec, front springs at 12k & rear springs at 10k,These are all alloy and are extremly light weight.
Full height adjustable-$1,800 BARGIN !!
*Kts full adjustable upper controll arms left & right set,Japanese made and you can get up to 5deg camber out of these 2000 klms old $300
*Kts rear camber arms pair-$135
*Kts rear toe arms pair-$135
*Factory front sway bar-$65
*Factory rear sway bar-$65
*Kazama front caster arms,Japanese made fits R32 Gtr,R33 Gtr & Stagea pair-$145
*Arc front sway bar adjustable,we all know Arc make the best stuff.These are like new.(Blue in colour) Front-$300
*Arc rear adjustable sway bar (blue in colour) Rear-$300
*Tomei hicas lock kit,elimates both electronically & physically the hicas system as well as the warning lights.Better than replacing your hicas with a dodgey china lock bar.Tomei-$130
*Power steer pump-$150
*Power steer rack-$185
*Steering colum-$100
********* MORE PARTS LISTED ON THE PAGE BELOW ******* MORE PARTS LISTED ON THE PAGE BELOW *******
*Welcome to pick the parts up from me and im located in Southside of Brisbane. *Interstaters i can post/courier anything you need as i get good rates on shipping.Pls ask for a quote or alternatively you can arrange your own shipping as im happy to help either way. * I would prefer phone contact or sms.I try to get on SAU once a day but phone contact will get you a quicker answer. CONTACT-0452-389-598 ***********MORE PARTS LISTED ON PAGE BELOW THIS ONE**********
Edited by BIGBOSS
  • Replies 53
$$ MORE PARTS HERE $$
_ELECTRONICS GAGUES & WIRING_
*Apexi power fc with hand controller 2000 klm old,comes with original box.Tune was done by Matt Spry (pits Gold Coast) Tuned with Nismo airflow meters,850cc inj,Hks 25/40's.Made 587 hp.Serial number for pwr fc-GTR 33L 020-0832
Serial number for hand controller-FCC3 020-04354.The power fc unit is for both R32 GTR & R33 GTR.Save yourself some money on a tune as it would only be 2-3 hours on the dyno to tune this to your existing set up.Pwr fc & hand controller-$900
*Nismo airflow meters,2000 klms old.The advantage of using Nismo air flow meters is you can use your factory airflow meter plug (no need to chop and modify like you do when using z32's)They are also the same diameter (65mm) as your standard airflow meters,so the flange will bolt straight up to your existing piping or airbox without mods.
Nismo afm's also have the same airflow vs voltage curve as the z32's.
Standard AFM's twin-1400kg/h max 430hpNismo AFM's twin-2400kg/h max 750hp Serial numbers on Nismo AFM's 1-22680rr580/a36-000j71/ox20a, 2-22680rr580/a36-000j71/ox20b.Pair of Nismo afm's-$680
*Mines 320KLM dash showing 31,000 klms-$360
*Factory centre gagues-$90
*Splitfire coil packs 2000 k's old,comes with original box.Fits GTR 32/33,Stagea Autech,series 1 r33 GTS-t,rb20det,rb25de,rb20de-$450
*4WD controller,i bought this off an Aussie company (can't remember the name) controlls have a dial up to 10 with a switch for 2wd/4wd works great (see pic of interior.It's located on centre console)-$150
*Greedy full auto turbo timer,2000 klms old and i have the original box.I paid $189 sell for-$90
*4wd motor & associated bits-$350
*G sensor-$400
*Ac display-$110
*Headlight switch-$85
*Wiper switch-$85
*Injector harness,bought this brand new from Nissan.Done 2000K klms (have reciept)- $150
*Engine harness,again i bought this brand new from Nissan.Done 2000 klms (i have reciept) new price is $1,111 sell complete- $535
*Gearbox/knock sensor/alternator harness,bought brand new from nissan 2000 klms old- $145
*The rest of the harness (complete rear section)-$375
*Injector resistor pack-$125
_EXHAUST_
*Rsr front pipes,Japanese made.These are a work of art (as pics indicate) the bends are lobster-back,full stainless has Rsr & serial number stamped on them.Inside diameter is 2 3/4 inch where dumps (outlets x2) bolt to then goes to 3 inch where it joins to the decat pipe.These will make a great improvment along with dump pipes.Rsr cat back 3.5 inch stainless system made in Japan,stamped & serial numbered.Has 1 muffler in centre and rear muffler+ 5 inch tip.(see pics)This whole system is very quiet & at idle all you can hear is the cams (if you have a pair of AM CAMS).Its a full legal system and Rsr claim its rated around 92 db.This system sounds great under full noise! This exhaust supported well over 550hp.I would like to sell this whole set up as a package so front pipe,decat pipe & cat back system complete-$1,100
*Hks dump pipes wrapped in heat wrap (02 sensors not included) -$400
_COOLING & INTAKE_
*Apexi power intake,elbows with pods & brackets-$225
*Hks complete hard pipe kit (intake racing chamber kit) with intercooler piping.I have had the whole lot HPC coated by competition coatings (Brisbane) at a cost of $480.I have also replaced the thin Hks silicone hoses with 3 ply UK (England) made silicone hoses which were bought through ARE (Brisbane based alloy radiators engineering) cost $380.So its a worthy upgrade from your standard HKS hard pipe kit.
This kit contains the intakes for the turbos,top section with AFM adaptors and bottom section for intercooler piping (see pic).Also just for good measure ill throw in the power steer resovior + Hks brackets,and modified power steer lines to who eva buys this complete kit as that makes it a piece of piss to install everything! Complete kit-$1,300
*Koyo radiator R series,53mm core,2 layer.2000 klm old.Drop your water temp down by 30%.The standard fan schroud fits directly up to this.-$450
*Factory fan schroud (fits r32 gts-t as well)-$120
*Hks remote oil cooler kit.Comes with everything including lines,adaptors,nuts & bolts.This cooler itself when installed in Bnr32 fits directly in front of your ac condensor and looks like a factory fitment.(I have pics of it installed) Fits any RB engine & a definate must have to keep the oil temps down.-$650
*Samco radiator hose & heater hose kit.2000 klms old & made in Japan.Top & bottom radiator hoses + heater hoses.The kit new was $500+ sell for-$300
*Ac condensor-$100
*Ac fan-$65*Ac lines ? call for a price..
*Ac under dash bits ? call for a price..
*R34 GTR factory intercooler made in Japan (calsonic),exelent condition (silver) with no dents or damage $330
_BRAKES/GEARBOX/DIFF/HUBS/CROSSMEMBERS ETC_
*Abs unit-$325
*R33 gtr Brembo brake master (had this re sleaved)-$250
*Brake booster (new diafram fitted)-$125
*Nismo 1.5 way rear lsd complete diff (bolt straight in) $800
*R32 GTR gearbox (push type) had been rebuilt in Japan in 2004 (done 4000 ks since) but im not certain what was done.Good condition-$850
*Complete tailshaft-$120
*R32 GTR gearbox mount & gearbox cross member-$145
*R33 GTR front hubs pair-$300
*R33 GTR rear hubs pair-$300
*R32 GTR rear hubs pair-$300
*Front drive shafts each-$125
*Rear drive shafts each-$125
*R32 GTR rear cradle with aftermarket alloy pineapples-$350
*Hand brake asslemby with black drift button-$75
_UNDER CAR PLASTICS_
*Front brake ducts, pair-$100
*inner guards,has slight wear mark where wheels have rubbed,left & right each-$55
*Splash guards,left & right each-$25
*Plastic that sits under engine good condition-$75
*Fuel tank-$150
*Straps for fuel tank-$70
*Radiator over flow bottle-$20
That"s about all i can think of atm,but if there is somthing you are after and i havent listed it, please get in touch and i will do my best.I would prefer phone contact.
Edited by BIGBOSS
I'm very sad this is happening to such a quality GTR
but like others I will help out by buying off you ( picking the bones clean)
See my PM for parts wanted :thumbsup:
Steering wheel, HKS oil cooler, Drivers side Glass, Centre console, 4wd/2wd switch, steering/suspension bits n pieces, Carpet and other stuff.
shotgun full exhaust system, koyo rad n hks hard pipe kit
....if they are already sold :S
cheers Aaron, should have a drama gettin rid of any of those parts
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
