I "tested" it by going on a long drive in manual mode when I was running the PWR and Mishimoto trans coolers in series (no radiator in tank regulator), both of which were mounted on brackets and not touching the radiator at all.
Was curious as to how hot the coolers got so did the drive and put my hand on the PWR cooler when I got back. It was quite warm. The only time the car was out of manual mode was when reversing out of the driveway.
Scientific? No. Logical? To me, yes.
OK, so now I'm confused. If the gearbox stopped pumping fluid thru the trans cooler/s when in manual mode, wouldn't they be cool(ish) to the touch after a drive using nothing but manual mode?
The standard temp of the fluid should be about water temp or a bit higher (since it flows thru the radiator cooler normally), so did 'quite warm' feel significantly less than say 90 deg?
  • Replies 93
i still dont rekon it completely stops flowing through the cooler. i think it there is a valve that ups the pressure for make it more 'sporty' but at the same time restricting flow to the cooler....... thats my theory anyway
That's what i am saying Leon. The cooler was "quite warm" because it was doing its job and cooling the trans fluid.
Whether there was some kind of issue that allowed the fluid through my coolers when in manual mode or not, who knows... but I can't for the life of me think/believe that Nissan would stop the fluid from being cooled when in sports mode.
Just not logical to me.
NFI on the temp. I only put my hand on the PWR cooler but being where it was situated there is no way it could have had heat soak from anywhere on the car.
Great, thanks for clearing that up - I thought you were supporting the 'no cooling in manual mode' team with your info, hence my confusion.
I too thought it strange that Nissan (or anyone) would design the transmission to not send fluid thru the cooler when you would need it most.
That would also help to explain why I couldn't find any reference to this process in info on the ECU/TCM & AT in the manuals.
I'll try to do a similar test sometime to see if my result is the same as yours.
That "team" was the mob that built my auto, Kewish auto. I didn't doubt them originally as in manual the torque converter is always locked, therefore not flaring causing excess heat.
Now I believe they arent right but I havent bothered checking. Mine could be working in manual mode due to cutting the converter lockup solenoid wiring so best if you guys check.
I have the full Re5 manual at home, there is definitely a cooler valve so it must turn off sometimes.
Perhaps while it's reaching operating temperature it remains closed?
On mine at least, in manual mode, 5th gear isn't available until the box reaches temp either.
I would assume this is also to help it get to temp quicker (or the transmissions f$%(ed pinch.gif)
That makes much more sense, other than the fact the radiator is used to get the trans fluid up to operating temp quickly.
I believe the transmission fluid is always cooled through the radiator both in auto and manual.
The bypass is there as a safety to provide the gearbox with lubrication in the event that the return fluid from the radiator is blocked.
The transmission fluid will never be any cooler than the engine water temperature, hence some people fit aftermarket transmission coolers to give additional cooling closer to ambient air temperature.
At least, this is what a transmission specialist told me.
Still have not got mine booked in to get the the bottom of the problem.
Chris
But how did an RS centre console get into an AR-X....
And would that explain why the gauges do not work, i.e. no senders...
Yep, no senders!
So that's an easy decision.
Anyone need some RS centre console guages?
I'm fitting a double din head unit.
Chris
Yep, no senders!
Chris
I like the look of the unit you mentioned the other day Chris.
We put a very similar double DIN unit in ours a year or so ago, removing the triple gauges and love it!
You could pay a lot more for a brand name but I'd rather spend the money elsewhere on the car.
You won't miss those gauges, they do SFA most of the time and the accuracy of the boost gauge is average at best.
Plus, if you want gauges you can run something like HKS CAMP2 into the video input on the head unit. That's what I'm planning on doing: remove the single DIN stereo and gauges, and put in a double DIN with a HKS CAMP2 wired to the F con.
If you're lucky you can get one new out of Japan or the US, or there are plenty of second hand ones.
Streeter priced it up for me at around $500 landed out of Japan, but there was also one on ebay motors recently.
One of the russians is playing with a Camp2. His build thread is pretty interesting in general actually, hes basically a russian Leon in my opinion :P But he rocks awesome stickers as if his name were craig :nyaanyaa:
http://www.avtobazar.com/forum/viewtopic.php?f=7&t=3713&sid=d0d5c11922cdf697d4f5e55fb5c5856e&start=416#p140379
Google translate is pretty terrible at russian, but the pictures are good!
http://www.avtobazar...art=416#p140379
well we know where all the left over new parts went! Bloody hell his spent some money with Nissan.....he also has more gimmicks and lights on his car than Andy! :P
LOL. Eugene & I may have a bit in common so I decided to add him to my sig. He's certainly spent some ruples on his Stag. Who was it in WA that had trouble getting the cruise function on the Pivot throttle controller to work (Tom?). Just ask Eugene, he got his working, after a bit...
So getting back to my transmission problem i have made a discovery.
Firstly the dealer offered to buy me a used transmission that I had found for about $1,300 and said i should pay for the installation as the car was not covered by statutory warranty. Then I realised he had made a mistake and indeed the car was under stat warranty as it was less then 10 years old. Built 05/02 it just gets into the warranty period.
Now the dealer wants me to send the car to a garage in North Melbourne that want to look at the transmission.
(starting to wish i had not questioned the warranty and just taken the replacement transmission when offered)
Now i discover that a mystery switch in the car actually seems to do something.
With the switch in the on position the transmission seems to be fine.
With the switch in the off position, I cant go 30 or 40 K before it goes into limp mode and sometimes it goes into limp mode every few k's.
Resetting the ignition clears the limp mode and all is normal again for a few more k's, maybe.
Question is, what does this switch actually do to patch up a fault in the transmission????
Someone suggested it locks the torque convertor to prevent slip. If it is worn, the trans sees the slip and goes into limp.
What should i do now?
Tell the dealer about the switch, or just leave it in the off position and let the transmission specialist figure it out.
I really don't want a sticking plaster on what could be a major problem, or is this a typicaly normal mod to extend transmission life?
Comments appreciated.
Cheers
Chris
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
