  • Replies 111
So seems work activated a nice new Internet connection...so I thought best to test it...
anyhow 14 gig in a morning makes me think it is now ok for the rest of work to use.
http://sau.loudsx.co...A%20feb%202012/
will do low res ones tomorrow as well basically I cannot be bothered today.
You are a legend - was gunna offer bandwidth to assist but looks like you have it all covered!
oh and usual request, if you reuse these on FB/youtube etc please reference SAUVic and myself as the camera operator.
So do I list "Martin" as camera operator? Or something more specific?
cant view MTS files at work :'(
also cant install VLC :(
Grab portable VLC - doesn't need to be installed, just runs locally: http://portableapps....eo/vlc_portable
Damn you DECA! Here I was trying to be all sensible with my money, looking towards the future and all that. First day back and I've already done half a dozen searches on carsales, checked out my105 and scanned the for sale section.
Good stuff! Im glad we had an effect on you...dont wait too long, otherwise youll never do it!
Some pretty nice driving out there this time round, I think everybody should watch out for Ben, out there for the first time and by the end of the day within one second of the fastest times on the skidpan, also beating the notorious Russell Cunningham on various occasions!
Thanks to Luke for the ride in the unbelievable NUTR33...a truly impressive setup!
Thanks to all who participated and provided great company during drinking festivities! Even though the poor had lots of floaties in it it was so awesomely refreshing after a full day in the sun!
Thanks heaps to all the volunteers of the day, awesome day despite the heat, still amazed that my car survived.
Thanks Martin for all the videos, have not watched them yet, cos I'm on a slow connection at the moment, but will have a look when I get home
Also, I wanted to ask, Martin, I want to make a montage of my runs of the day using my go-pro footage, and your external footage, how would you like to be credited? First & last name? Forum name? both?? Let me know, Cheers!!
Will def be at the next one! Hope to see everyone again!
Edited by she_spools_180
Great day. Thanks to all volunteers etc!!
You weren't the only one single pegging out there ash :(
Didn't manage to get time to throw locked diff in so it was a handleful to try and slide round.
Can't wait for next deca.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
