so today i received my Tarzan G Box in the mail, so it was straight down to the garage to put it in.
here is what the kit contains
unplugged the old sensor and slid the plugs off
new one plugged in!!
Now that was all well and good but once trying to re fit the centre console, i bumped into my first problem..... the g sensor now sits too high ontop of the standard position. Which stops you from putting in the side screws and if pressed down too hard, pops off the coin holder compartment.
Due to time constraints, i just had to leave it for now and come back to it.
The Test Drive
During normal driving obviously there is no notice at all, its until you press down the accelerator that you really notice the change.
I brought the mrs along to have a second opinion as she loves the R to bits :P
We both confirmed straight away that acceleration has now become a lot smoother, almost so that it feels that the power has dropped back. As there is no longer the hard kick when the turbo's come on!!!
Then through corners it instills courage as the car is noticeably more planted and firm, its almost like you can feel the attessa working more and sending the power where it should be. Also you can tell how much more responsive the torque needle is (even though reading its not really accurate) when sending torque to the front.
Yes the braking feel has also been improved, there is less movement and the weight seems to transfer alot smoother also when getting on the middle pedal.
Lets just say that it put a smile on my face and has change the way the car handles, so i give it a thumbs up. Yes it is a bit pricey, but hey its what cars are about!!
Looking forward to going for my next drive already!!
  • Replies 102
Posted Images
I have a couple of negative opinions on the build for this car. It was a pretty clean series 3 except the bonnet at the start. You did the right thing changing it back to factory bonnet. Series 3 is probably so rare that I would expect owners to keep it full factory on the exterior and minimal change on the interior. those blue LED really shouldn't have gone in factory boost and oil temp gauge in the centre...Carbon dash and centre console is kindda ok but Id really still keep it stock unless they are really scratched up. And that front lip is really something there to just ruin the beauty of an r33. A genuine series 3 V spec front lip is more than enough to make your car look mean. With cars like GTRs looks, more is less and less is more. Last but not least, a GTR has to have big power, so save all that effort for making it a fast powerful and RELIABLE weapon. Good luck.
Interesting views, but it is up to the owner to decide what he does with his own car. If what he is doing makes him happy and its getting closer to perfect in his eyes - that's all that matters.
Some nice features on the car Raimie, keen to see the progress and end result!
Thanks for all the input guys, Wei- thanks for your input but at the end of the day your view is going to be different to someone else's. I've had ALOT of positive feedback to how the R looks now as photos don't do it justice and hey, not every is in for the clean look. The Japanese time attack/street tuning style is what I aspire to hence the lip. Let's face it how much of that BIG power can you use on the street (where mine is driven 100% of the time) and if it's making big power reliability is another thing all together, plus maintenance fee's. Bit of advice- let people build cars the way they want too, otherwise the scene would be dead and boring.
Anthony I got it through Jesse streeter.
Newest update
Racepace built R34 is now under my wing
Edited by JDM33
thanks James, hope to have some new photos of the R's soon!!
:thumbsup:
mods might have to wait till the new year. though there isn't much left to do on the 34
Was that Muztek's 34?
Shame I won't see it around Vic anymore. But you've managed to get a beautiful car!
  • 3 weeks later...
Bride's have been swapped from 33 to 34.
Trying to figure out what i want to do with the 34, performance wise i'm pretty happy, just a few things need changing/updating.
But il keeping the exterior how it is, mostly for now. Went for a cruise recently with some mates, including a 2.4LTR EVO VIII.
I only just received the San-Yon last week and i just want to drive the thing all day! well thought out mods both inside and out.
  • 1 month later...
Gee'd up the rear of the R with some Qest LED's this arvo.
after
The light is so much brighter and clearer now!!! Gonna look killer at night. Will post better pics once i'm finished with the rear
Very nice pair of R's Raimie. Needs some led tailights too. But at 1200 bucks a set i can't justify the cost. What does the tarzan sensor in the 33 feeling like? Make it handle abit more like the 34?
Thanks mate :) nismo tail lights have been ordered, just waiting on dispatch- mofo's ain't cheap! Yeah in a way I guess, the sensor is set up to under steer a touch more. But that's only once your really pushing it, with different suspension mods it's a bit hard to compare the two but the sensor has made the 33 a lot smoother to drive and more predictable
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
