so today i received my Tarzan G Box in the mail, so it was straight down to the garage to put it in.
here is what the kit contains
unplugged the old sensor and slid the plugs off
new one plugged in!!
Now that was all well and good but once trying to re fit the centre console, i bumped into my first problem..... the g sensor now sits too high ontop of the standard position. Which stops you from putting in the side screws and if pressed down too hard, pops off the coin holder compartment.
Due to time constraints, i just had to leave it for now and come back to it.
The Test Drive
During normal driving obviously there is no notice at all, its until you press down the accelerator that you really notice the change.
I brought the mrs along to have a second opinion as she loves the R to bits :P
We both confirmed straight away that acceleration has now become a lot smoother, almost so that it feels that the power has dropped back. As there is no longer the hard kick when the turbo's come on!!!
Then through corners it instills courage as the car is noticeably more planted and firm, its almost like you can feel the attessa working more and sending the power where it should be. Also you can tell how much more responsive the torque needle is (even though reading its not really accurate) when sending torque to the front.
Yes the braking feel has also been improved, there is less movement and the weight seems to transfer alot smoother also when getting on the middle pedal.
Lets just say that it put a smile on my face and has change the way the car handles, so i give it a thumbs up. Yes it is a bit pricey, but hey its what cars are about!!
Looking forward to going for my next drive already!!
  • Replies 102
Posted Images
I have a couple of negative opinions on the build for this car. It was a pretty clean series 3 except the bonnet at the start. You did the right thing changing it back to factory bonnet. Series 3 is probably so rare that I would expect owners to keep it full factory on the exterior and minimal change on the interior. those blue LED really shouldn't have gone in factory boost and oil temp gauge in the centre...Carbon dash and centre console is kindda ok but Id really still keep it stock unless they are really scratched up. And that front lip is really something there to just ruin the beauty of an r33. A genuine series 3 V spec front lip is more than enough to make your car look mean. With cars like GTRs looks, more is less and less is more. Last but not least, a GTR has to have big power, so save all that effort for making it a fast powerful and RELIABLE weapon. Good luck.
Interesting views, but it is up to the owner to decide what he does with his own car. If what he is doing makes him happy and its getting closer to perfect in his eyes - that's all that matters.
Some nice features on the car Raimie, keen to see the progress and end result!
Thanks for all the input guys, Wei- thanks for your input but at the end of the day your view is going to be different to someone else's. I've had ALOT of positive feedback to how the R looks now as photos don't do it justice and hey, not every is in for the clean look. The Japanese time attack/street tuning style is what I aspire to hence the lip. Let's face it how much of that BIG power can you use on the street (where mine is driven 100% of the time) and if it's making big power reliability is another thing all together, plus maintenance fee's. Bit of advice- let people build cars the way they want too, otherwise the scene would be dead and boring.
Anthony I got it through Jesse streeter.
Newest update
Racepace built R34 is now under my wing
Edited by JDM33
thanks James, hope to have some new photos of the R's soon!!
:thumbsup:
mods might have to wait till the new year. though there isn't much left to do on the 34
Was that Muztek's 34?
Shame I won't see it around Vic anymore. But you've managed to get a beautiful car!
  • 3 weeks later...
Bride's have been swapped from 33 to 34.
Trying to figure out what i want to do with the 34, performance wise i'm pretty happy, just a few things need changing/updating.
But il keeping the exterior how it is, mostly for now. Went for a cruise recently with some mates, including a 2.4LTR EVO VIII.
I only just received the San-Yon last week and i just want to drive the thing all day! well thought out mods both inside and out.
  • 1 month later...
Gee'd up the rear of the R with some Qest LED's this arvo.
after
The light is so much brighter and clearer now!!! Gonna look killer at night. Will post better pics once i'm finished with the rear
Very nice pair of R's Raimie. Needs some led tailights too. But at 1200 bucks a set i can't justify the cost. What does the tarzan sensor in the 33 feeling like? Make it handle abit more like the 34?
Thanks mate :) nismo tail lights have been ordered, just waiting on dispatch- mofo's ain't cheap! Yeah in a way I guess, the sensor is set up to under steer a touch more. But that's only once your really pushing it, with different suspension mods it's a bit hard to compare the two but the sensor has made the 33 a lot smoother to drive and more predictable
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
