That's why I asked - the bonnets shape around the headlight looks to be slightly different to the nm35 headlight itself
Pic for your reference although no bonnet, you can see where the "tabs" sit in relation to an NM headlight.
less gears in an auto the better ;)
You'd better get in touch with Mercedes, it's time someone with real insight told them they're doing it wrong...
Oh no! Based on Aarons' advice I just bought a 2 speed Powerglide tranny to go in my M35. Back to the drawing board I suppose.
Spool that baby up Leon; 8000rpm stall = mad skidz bro!
LOL at Aaron's successful trolololol
Nah mate - you haz ultimate- NO gears!
How'd that work out for Nissan :ph34r:
Too hard for Mr average no-brain to service with correct fluids at the correct intervals (on that note, I wonder how often - if ever - people change the filter near the cooler).
Nothing wrong with that transmission Alex, just the tool behind the wheel/under the bonnet.
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
    • Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
