Also comparing 250kw (thats well over 400hp btw) on a road with potholes and telephone poles and all sorts of other scary shit that can and will kill you or somebody close to you very very quickly and unexpectedly..
To having 250kw on a controlled skidpan, dragstrip or racetrack is again comparing apples with oranges..
Actually... It's 335HP not well over 400HP...
Have kids just started failing simple maths lately?
  • Replies 106
lols...tell the truth you googled that..
crank hp is what I was suggesting,(probably should have stated) I guess you failed the mind reading class :P
20yrs ago when boosted turbos and dynos werent so common, if you had a 400+hp street car you were the man...
It is still enough for a very quik car but people seem to lose sight of that...
Ummmmm just me but 250 killer wasps is not well over 400hp
Oh and this thread is pointless
As nismoid said too many factors like diff ratios gear changes etc go to an import yard and test drive something quick
Its worse than that, they're failing youtube
Okay, this whole thread I've been facepalming something shocking at the stupidity... I get to this and nearly wet myself laughing...
BRB, going toilet...
That reminds me - here's a .82a/r internal gated GT3076R setup with similar power:
Its over 250kw, not quite 300kw - so doesn't answer either of the specifics but still gives an idea of what a very basic internal gated GT3076R setup can go like with a safe tune.
That turbo is capable of much more on more boost/better manifold/external/cams etc, but still makes for a good all around setup.
This seems WAY faster than youtube vids I've seen of sub 240rwkw skylines, but as Nismoid says, too many factors to judge the reality, nevertherless still a good means to get a good idea for people wanting to set their power goal.
That reminds me - here's a GT3076R setup with similar power:
Thanks mate I did see that on youtube before and was goin to post it, you beat me to it..Thats fast man - must be around 280-300rwkw seeing its a 3076R.
Edited by rondofj
Yep it was in that range on the dyno I tuned it on and it seems thats the generally accepted range for that type of setup on that type of boost.
I didn't mention numbers as people on here get all weird about dyno types - so stuck with the basic facts, this is the kind of performance you should get with a stock RB25, stock manifolds, decent exhaust intercooler and ECU and about 17psi running on 98RON. Tune and all else being equal the real world results shouldn't vary too much, regardless what kind of numbers on what kind of dyno.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
