5 min job. From underneath. Look for a long 10mm bolt facing vertically. There is one for each belt.
Also, inspect the belt for cracking on the ribs on the inside. If its too bad or brittle, replace it.
And don't forget to firstly loosen the idler bolt before trying to tighten the belt. Otherwise the idler won't slide.
Probably obvious but I made that exact mistake!
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-6289409
You can replace your belt with soap!!!?!?!??!?????????!!????,?,!!!!!!!!!!?!,??,?,???!!???!!!!?!?
Instead of using brake fluid which will eat your paint if it comes off the belt lol
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-6289483
  • 3 years later...
Dragging up an old one here, the bearing on my aircon pump or tensioner Seems to be on its way out, I can't quite put my finger on it, has anyone replaced this before? Don't want to pull it off without parts on hand, anyone know the part numbers?
Many thanks,
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-7555667
I suspect it may be a bit of a major - definitely if you lose your coolant. May be a job for an air-cond shop unless someone knows better.
No coolant loss, hard to describe but it's like a chirping sound proportional with revs, comes and goes, my guess is the bearing attached to the pulley on the pump itself might be on its way... Which yeah, could be a major, I'm quite rookie at this fault finding stuff lol
https://www.sau.com.au/forums/topic/395879-slipping-belt/#findComment-7555682
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
