I run a non ethanol 400lph walbro instock R32 GTR position, has been in for almost a year now sits there corroding away... I mean dorment for months at a time as the car doesnt get used alot.
Has no problems pumping 400kw on stock pressure with id2000's
  • 4 weeks later...
I got a walbro e85 450lph pump and wired it with thicker cables via a relay to get full 14volts
Had it tuned the other day on e85 and it seemed to run out of puff at around 360-370rwkw....didn't have time to check it out yet, I'm going to double check the voltage at the pump and give the sock a clean after a few tanks of ethanol incase it get clogged of shit
Anyone had this issue? My battery is in the boot so the power cable is short, also noticed the pump is very quiet, is this normal?
Any suggestions guys?
I have the 416lph and im at 360kw so you should be able to get enough fuel with the 450lph..
I had a 20A fuse protecting mine and it blew after 1000ks so it must be pulling 20-25A, 2.5mm wiring all the way to the pump would be sufficient however I would prefer to use 4mm for the bulk of it and you should bypass the standard plug through the lid.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
