  • Replies 7.5k
Posted Images
Vange - I have had good service and results from Turbo Tune, so I wouldn't worry. Michael has tuned my S15 for 2 years and always has a safe/rich tune (at my request), and will not try to get every last rwkw at the risk of detonating an engine (like some other tuners around will).
Every workshop has people who have had bad experiences, so don't worry about what everyone has to say.
My car was last there 2 months ago and I am very happy. Lots of the stories you will hear are from x years ago - so aren't really up to date. That said, everyone is human and every single workshop has had some sort of mistake or failure that people will always tell you about. You hear little of good reports.
However, Boostworx is one workshop I have heard nothing but good things about. Maybe get Shaun to put it on his dyno just to make sure the tune and afrs look ok - if you are worried, that is.
Graham West on Marion Rd can tune the eManage.
I only ever did a power run on their dyno, so can't vouch for their work, but from talking to them they seem like really a good bunch down there.
yeh im not worried, was happy with the boost controller they put on, n he set it at max 10psi so i dont blow anyting. seems 2 b running ok anyway...got new sparkies as well, the others were stuffed lol.
i might have 2 get it re-dynoed cos since it was last dynoed i had new clutch, new spark plugs and hiflow cat.
was thinking of getting a emanage, how much they cost 2 get installed, prob do the fuel pump as well...any1 know if the fuel economy gets better or worse with an emanage or better fuel pump?
i get mine done at hitech dyno on south rd, so does Phu 'PHUMAN' and he highly recommends it. Boostworx wouldnt touch my emanage ultimate, the guy said he had to call John (hitech) to get it to work as he couldnt figure it out??? I was shocked. Still got my fuel pump done there and is fine. Should be getting my emanage ultimate put in before the up coming cruise
Whats to be shocked about. Shaun specialises in Power FC's and Microtech computers...Hitech may know emanage and something else. You cant expect everyone to know everykind of computer out there...
hey hot chick spotted in a R33.........
brunett in a black 33 ser 1 m spec on OG road turning right to marden shops at 4:45pm today, anyone on forums ?
gotta love hoy chicks in lines.....
Edited by trick
yeah spotted DriftR_33 yesterday went for small cruise through the windies!
spotted silver 32 at Mobil servo Morphett Vale, stopped and chatted compared cars, mods.
Good to see other 32's getting around. :(
spotted chick in burgandy 33 on South road
spotted a black 32 on the espi and another white 33 at Woodroft with P's
alot of skylines out today!
Edited by HR-32
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
