  • Replies 7.5k
Posted Images
or u could go industrial shoot, which is something different to, know a couple of good quiet spots round port adelaide
back on topic, i THINK i spotted madaz this arvo on south road at regency park - except goin the other way for a change
Spotted a white R33 with plates XEDGEX or something in Modbury, still tryin to figure what that stands for.
Are they the same spots that CSA were looking at when they were scouting for places to do a shoot?
If it is...the backdrops are quite something else. :P
yes you did we both spotted each other but too late to wave :P
industrial with a good mural backdrop would be sweet
not sure patrick, but ive sussed a few spots out with a few of the 31 club boys, plus found a couple of nice spots by pure chance
yep, I'll organise something soon .... one of my mates is an awesome photographer with all the gear - we'll do a midnight shoot with some awesome backdrops like this : here (click)
I have always wanted some photos of my car with a scantly clad girl ......mmmmm...... i know a stripper!!!!
That sounds like a great idea.
Count me IN, no OUT, IN, OUT. oh oh - sorry
Edited by 4door_Sleeper
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
