spotted madaz comin from cavan road onto port wakefield road bout 3:45 this arvo
i was waitin to turn from pt wakefield rd into cavan rd...........seen u comin round the corner..............half climbing out the window waving, tooting and almost tempting to hit limiter to get ya attention LOL
lol yeah i like that corner so always pay attention to get a good run off it :D
  • Replies 7.5k
Posted Images
spotted, VANGE in boostworx, had a good look in your engine bay. and sinista's car outside all prepped up and ready2go. picking it up in an hour arent u u lucky bastard lol. ill catch up with ya tonight.
spotted a blonde chick driving a 33 kit rims
spotted a blonde chick driving a white S13 fairly stock
whats with blondes n white imports :wave:
Are you complaining?
Spotted black S2 33 with whits drivers side door at marion today, front bar falling off, missing parts of spoiler?? what the....must be one of those newspaper cars where you get a part each week...
WOW it's almost SAUworx ATM, with Vange, whatisname and Sinistas cars there! :rofl:
and me going there everyday after panorama tafe to check on sinistas car... my car will be there soon.
yeah hope to have mine there soon doing a new clutch
SPOTTED -
At about 8-15am this morning at the cornor of montague and bridge rd opposite the hyundi dealer, saw a beautiful looking midnight purple R33 GTR with the number plates VSPEC. Great looking gold rims also!
Dunno if its anyone off of here but still gave a wave!
Gun metal 32 GTR on Deeds Rd North Plympton! Thought i may have seen a SAU sticker on the rear quarter window???
It could be slimjim's.
Think I spotted Nightcrawler again this morning in Ridgehaven/ Modbury.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
