  • Replies 7.5k
Posted Images
deluxe you owe me a f**ken tooheys buahahah. howd the rest ur sat night go?
Yes Yes i do! I still can't believe you touched that girls.................................................Tattoo just above her crack! That was gold! Yeh mate the rest of the night went well, I saw you at Electric Circus also, I didn't think you were gonna go there! The next night was good also! But now im sick as, hoping i'll be all good for this weekends battles!
spotted a dark blue GTR32 wif plate LORENZ or alike at walkerville tce..was next to me at the lights and raving for a dragg..unfortunately my boss was just behind me and dun wanna ruin my reputation at work..lol..nice solid ride
Are you sure the plates were LORENZ? Where they Silver writing on a Black Background? Because an R31 was stolen yesterday that had these plates, and this morning the car was recovered, but the plates weren't. IF it was the case, please report it to the police!!
definitely a +1 on reporting that
i believe a few of the 31 club boys may still be willing to put in for a cash reward to ANY information that leads to the apprehension of these pricks
I'm not quite sure if it is silver on black..my glance was white on blue..but im definitely sure it has LORENZ on the plate..it may be LORENZ+numbers..not quite sure...it has a GTR badge at the rear trunk..
SPOTTED
A R31 i believe, number plates GTS 055 last night near parafiled airport at around 10. nice car, saw the SAU sticker on it...
Hey pal that was me.... was headin home from the gf's in my daily driver r31 GTS2. Its build #55 hence the plates.
Tidy 33 you have there..
Edited by HOSTILE
spotted madaz at jbhifi modbury last night, thought i reckognised you in the shop but it just didnt click. i was there pickin up my new plasma and ps3 lol in the missus wrx.
ah yes you did i was trying to play PG3 on the exbox << :) funny typo so i left it any reason for plasma and not LCD Bravia X series maybe :D
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
