  • Replies 7.5k
Posted Images
Spotted a white R32 at modbury next to the stairs near the underground carpark by woolies. Had a front mount, sunroof and the most important thing, an SAU sticker in the back quarter window.
Parked next to you because I knew I wouldn't end up with a door opening into the car.LOL
Yeah thats me :D you must have left before me, I would've noticed a skyline next to me
doing some shopping for the hot weather coming
Spotted a SHIT HOT red Mitsubishi FTO labelled with stickers all over its drivers side passenger area... gave driver nod
also saw a dark blue (or purple) R33 (think it was a gtr) on goodwood road. Followed it from cross road intersection to south road city,
saw a very nice bright yellow 180sx being transported on the back of a flatbed for a crash repairer. Looked bloody awesome. Again goodwood road, cross road intersection.
-D
spotted Mr ISC-Performance, i was the random in a camry tooting and waving.... soz =(
was hoping you were gonna keep heading along marion road so i could chat with ya, your store around where you were doing the u-turn? =D
Edited by Fishpaste~
was hoping you were gonna keep heading along marion road so i could chat with ya, but just tooted and waved =D
haha...I was wondering who that was I was going to flip you the bird.. :D Store is next RD over. Adress is below in Signiture.
Ryan :laughing-smiley-014:
spotted sinista on magill road this arvo a bit before 4. was headin the other way (i waved but then once again realised im driving a commodore LOL). ya had a white 34 not far behind ya..................either it was u or theres another body double of your car, silver mirrors and all LOL
spotted a dick load of skylines at lofty's tonight, i was driving a mates pimp celcior, the 33 was chillaxin...nice turnout of skylines especially GTR's.
also spotted a few skylines having a chin wag at super cheaps at near coca-cola.
Edited by Ryanrb25
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
