  • Replies 7.5k
Posted Images
spotted MissR34's white beast yesterday rolling through my gheto in the north subs :) only i may drive a nice car in that hood thank u
hope you had your doors locked young lady :D
:blush:
and yes my doors are always locked
today within the hour of me driving home, spotted about 12 r33's!!!! including "theace" on salisbury hwy, also 2 r32's and this morning on the frost rd/main nth rd intersection r34 silver with nismo kit and bronze rims..........rekon it was the one i saw the other day
White 32 this morning, turning out of Clarendon Rd onto South Rd. Had black wheels similar to drift-teks but had polished rim, lowered exhaust etc. Drove next to him for a while in the SP23, anyone here?
Spotted I think OUTCAST on North East Rd near the Munno Para shopping center
Yep that was me...WoooHooOO!!!! I think we were looking at each other as I got a quick glimpse of your car going the other way.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
